SOURCE: Maytag Bravos series
Its called Affresh, thats the tablets, you can go to www.affresh.com it will ask you for your zipcode, enter your zipcode and it will tell you the closest retailer in your area that carrys it.......Krogers, Home Depot, HH Gregg, are some that carry it........hope this helps......
SOURCE: My Maytag Bravos quiet series
Hi and welcome to FixYa, I am Kelly. "Ld" (Washer is taking too long to drain water from the wash tub) Check the following: Is the drain hose kinked or clogged? Is the drain hose installed properly? See "Connect the Drain Hose," page 2-5. Press Is the drain hose clogged, or the end of the drain hose more than 96? (244 cm) above the floor? a) Loosen the clamps and pull the inlet and outlet drain hoses off the pump. Note that there is a tab on the outlet connector that fits into a slot in the hose. b) Remove the three 5/16? hex-head screws from the drain pump and remove -Disconnect the wire connector from the drain pump terminals. - Set the ohmmeter to the R x 1 scale. - Touch the ohmmeter test leads to each of the drain pump terminals. The meter Long Drain Ld flashes when the water level does not change after the drain pump is on. • Is the drain hose or the drain pump clogged? • Is the drain hose height greater than 96? ? • Is the pressure hose connection from the tub to the machine/motor control pinched or plugged? TEST #7 Drain/Recirculation Perform the following checks if washer fails to drain or recirculate. 1. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies. 3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1. 4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5. 5. Tilt machine forward to access the bottom of the machine and the pumps. See take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump. 7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power.Replace the machine/motor control assembly.
My response is very long and will be in 2 parts this is PART 1
Here is what the service manual says about Ld:
PAUSE/CANCEL to clear display
Also:
See "Drain System," page 2-3.
6. To remove the drain pump: (there are 2 pumps... the drain pump is on the left)
the pump from the tub.
Check the pump inlet and the tub outlet for obstructions.
Pump electrical winding resistance test:
should indicate between 10.5 and 14 ?.
----Due to the design of the machine the 2 wires going to the drain pump have be notorous for backing out of the plastic connector. Check the connector of the pump for loose terminal connections. --
From the Ld troubleshooting steps / procedure:
• Is the pump running? If not, see TEST #7.
TEST 7
Figure 1, page 6-13.
6. Check the resistance at the pump motor. Remove the connector at the motor and
Perform the Manual: Pump test.
SOURCE: I have a Maytag Bravos quiet series 300 and I
Hi F51 error is a rotor position sensor error. This error
appears when rotor position sensor is faulty or due to a faulty control board.
Look underneath the tub and check the motor, check for RPS on the right side
(follow the brown wires) and under the motors rotor disk. Use Allen
wrench to remove the rotor and then the four bolts holding the motor stator to
the tub can be removed. Hope this
helps...please post back for further assistance. Daniel
SOURCE: my maytag bravos quiet series 300 washing machine
i lost the manual , what does "5d" mean when it is
SOURCE: MAytag Bravos Quiet Series 300 washing machine
F-51 RPS senses rotation when basket ought to be stopped.
It is probably loose or worn out.
Video How To
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
