I tried to charge my headset and now the red light wont go off and the unit wont turn on or connect
SImply connect the headphones to a power source. Then press up and down volume buttons at the same time. It will reset the headphones.
I had the same problem tried this and it worked perfectly. You should note that the red light will remain while it is connected to the power, because it is charging, but if you disconnect the power then you can see the red light has gone off.
the red light doesn't blink if I connect the charger cable to pc or wall outlet
