SIM NUMBER IS 07504251671
SOURCE: HOW CAN I UNLOCK GLOBE SIM CARD PUK CODE?
Call your service provider customer care toolfree hotline . If they say this line " Not on prepaid but can check on postpaid." your somewhere in SEAsia.
Regards
SOURCE: unlock puk without knowing mobile number
Hi
try calling customer services at O2 or call into an O2 store. They maybe able to tell you the number from the sim number?
They will ask you to answer some security questions which are how much credit is on sim? When you last topped it up? How did you top it up?(i.e. voucher or etop up swipe card) If you cannot answer these then I am afraid they will not be able to give you the number (data protection act).
Good news is that if you go to an O2 store you can pick up a new free sim as long as you put £10 of call credit on it. Hope that helps?
SOURCE: vfone sim lock and iam un lock the sim my puk cod
PUK code can
be given only by your service provider which is specific for each and
every mobile number.
Contact
your sim customer care department over phone. Its free of cost
to get the pin or puk no. If you cant contact through your phone get
some other phone and contact them.
Go
to the nearest service outlet of your service provider they can also
help you.
There is no other go than the
above procedure only your service provider cangive it nobody else in
this world nor any software.
Go
to the below link and you can confirm that the above procedure works
and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
SOURCE: when i tried to activate my security cod my sim
If by mistake or forgot your Sim Pin code and enter the wrong code three times in a row, the sim will lock up, and you have to enter PUK Number to unlock it. You should ask your Service Provider for this code when you need it. Don't try to guess the PUK Number, because after a few wrong guesses, the sim will be permanently disabled (locked). If your Sim is permanently locked you can get a New Sim Card with the same Mobile Numder.
