The humming noise and non-functioning fans in your Sunquest Pro 24RS tanning bed could be caused by several factors. Here are a few things you can check to diagnose the problem and potential solutions:
- Check the power source: Make sure the tanning bed is properly plugged in and the outlet is providing sufficient power. Test the outlet with another device to confirm it is working properly.
- Check the circuit breaker: Check the circuit breaker for the tanning bed to ensure it is not tripped or in the off position. If it is tripped, reset it and try turning the tanning bed on again.
- Check the wiring: Check the wiring connections inside the tanning bed to ensure they are properly connected and not damaged.
- Check the fans: The humming noise and non-functioning fans may be caused by a malfunction in the fan motor or the fan blades may be obstructed. Check the fans for any obstructions and test the fan motor with a multimeter to see if it is receiving power.
- Call a professional: If you are unable to diagnose and repair the issue on your own, it is best to call a professional technician to service the tanning bed. They will have the necessary tools and expertise to identify and fix the issue.
In any case, it is important to exercise caution when attempting to diagnose and repair electrical equipment. Always unplug the tanning bed before attempting any repairs and do not attempt any repairs if you are unsure of what you are doing.
