Question about HP Pavilion dv6000z Notebook
I have hp pavilion dv6226us and when booted up the screen stays dark. You can see display only if you shine a light onto the screen. I tried to turn up the brightness and did't have any luck. Same thing and about 3 months past warranty end (of course). Yesterday I noticed the screen flickering a bit. Later, I went to use the laptop and the screen was very, very dark. I can barely make things out if a bright light is shined on the monitor. I've plugged an external monitor into the laptop and it works.
  • 107 Answers
You need a new back light http://www.google.com/products?q=dv6226us+inverter&btnG=Search+Products&show=dd
Posted on Dec 08, 2008
    President:
  • 2,110 Answers
Your LCD screen needs to be changed
6ya staff
SOURCE:
Pavilion g7-1173dx possible screen inverter issue?
The inverter is almost always below the screen in the bezel. You should only need a plastic pry bar (cost about $3) and you pop the bezel off from the screen side usually, you may need to check for screws under any rubber stops on the screen too. After the bezel is off the inverter should be on the bottom with two plugs into it. Unplug, pull it out and swap.
Sep 29, 2015 | HP Computers & Internet
Blinking motherboard led
When the following situations, you need to replace the LCD screen:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/hp-pavilion-dv6522em-lcd-inverter-p-4514.html
May 24, 2013 | Computers & Internet
My hp pavilion ze5270 notebook works fine except the screen does not lightup so i can see my displayed pages. if i shine a light directly into the screen i can see the page displayed on the screen or i...
well as i see from your problem explanation i believe that the LED which are at the backside of your LCD screen is not working so its better to troubleshoot from that angle.
good luck
Jan 05, 2010 | Computers & Internet
No display on screen
It's either the backlight lamp or screen inverter is busted. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Boot up.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the screen inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 25, 2009 | HP Pavilion dv9000z Notebook
Monitor goes on then off right away.
The backlight inverter is faulty.
THis means that there is either a loose contact or one of the transistors on the backlight inverter has blown
Jul 06, 2009 | HP Pavilion F1703 17" LCD Monitor
Display went dark
The backlighting is provided via the LCD inverter as you described.
Dec 08, 2008 | HP Pavilion dv1000 Notebook
My toshiba screen
Shine a torch light onto the screen. If you can see a faint outline of the images, it could indicate a back light failure. Unfortunately, you cannot fix this by yourself. You will need to take it for servicing.
Jun 11, 2008 | Toshiba Satelite A10 Notebook
The VGA card or the VGA driver is not properly installed,perhaps.Try reinstalling the driver.
If you suspect the monitor brightness controls then try fiddling with them untill the brightness is good enough.
Check monitor cable also(VGA).
Apr 08, 2008 | Computers & Internet
Display problem
When the screen goes dark shine a flashlight in the lower right hand corner where the Start button typically is located. If you can see faint images then you have a backlight problem. If you don't see anything then try connecting a spare monitor in its place. If that works then you have some other type of problem involving your LCD monitor. In both cases unless you have the experience and tools to safely work on fairly delicate electronics this is not a repair job for the typical consumer.
Feb 09, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion dv6000z Notebook Logo
283 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
