Hey Brain! What do i do!!! I attempted to Reinstall the Root Hubs that failed (yellow exclamation mark) and then i uninstalled the Yellow Exclamation mark ones, what do i do now? PLZ HELP ME!!!Hey Brain! What do i do!!! I attempted to Reinstall the Root Hubs that failed (yellow exclamation mark) and then i uninstalled the Yellow Exclamation mark ones, what do i do now? PLZ HELP ME!!!
You can't post conmments that contain an email address.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with post a reply hope it helps
Im Still really not sure what to do :P I attempted to Reinstall the Root Hubs that failed (yellow exclamation mark) and then i uninstalled the Yellow Exclamation mark ones, what do i do now? PLZ HELP ME!!!Im Still really not sure what to do :P I attempted to Reinstall the Root Hubs that failed (yellow exclamation mark) and then i uninstalled the Yellow Exclamation mark ones, what do i do now? PLZ HELP ME!!!
if you see a yellow exclamation or questin mark a new driver will need to be updated right click select update driver Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-fre... Windows XP/Vista/7/8 it might take some time being a freeware driver solution Note: it will find all of your outdated drivers This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.if you see a yellow exclamation or questin mark a new driver will need to be updated right click select update driver Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 it might take some time being a freeware driver solution Note: it will find all of your outdated drivers This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
You could easily pick up an aftermarket USB PCI card, which will give you 2-4 USB ports that have their own logic chip. These are quite easy to install and very inexpensive. Another option would be a front-mounted USB hub, which would attach to the USB header on your mainboard. They come in 3.5" size (to go in a floppy drive slot) or 5.25" for CD/DVD size slots. Either of these should work fine as long as the rest of the PC is OK. If not, they are pretty much universal, so you could put in your next computer. (if it didn't work). Good luck!
On the right hand side starting from the front to the back, the ports are
1. (2) USB Ports
2. TV/Cable jack if applicable, some models don't have.
3. RJ-11 Modem Jack
4. Security cable Slot
5. Power Connector
On the Left side Starting from front to back. the ports are.
1. Express Card Slot
2. Digital Media Slot (below the Express Card)
3. 1394 (firewire) slot (some models don't have)
4. USB Port
5. E-Sata Port
6. HDMI Port
7. RJ-45 Ethernet Port
8. Expansion Port Type 3 (attaching docking station etc.)
9. External Monitor Port
Hello frustrated:( lol)
if you boot you machine into bios and go to the usb section which should be under periphals section you should be able to see the usb now ensure that it is all enabled once you have done that just make sure that you save the changes and reboot your machine. and hopefully it will now take care of the problem that you are experiencing.ok?
best regards
mike
Putting the keycap back on is usually fairly easy. Many will snap back into place if you place the keycap back into the correct position and gently press it down. Look on the back side of the loose keycap and see if it has 4 small clips or if it has 2 clips and 2 slots. The one wit 4 clips should snap back on. The one with 2 slots requires you to get one side of the key hinge into the slots before pressing it down onto the other 2 clips.
If only some of the keys stopped working, that usually indicates a defective keyboard. Try connecting an external USB keyboard to see if all the characters work correctly. If the external keyboard works but the laptop keyboard does not, then you will probably need to replace the laptop keyboard.
