THE SCREEN SHOWS RECIEVED IN MEMORY AND THAT THE OUT PUT TRAY FULL
If you open the cover,the same cover you open to replace the toner.There is a guide that can swing up and down.This sensor is situated in this guide.Swing this giude to the down possition and you will see the arm that actuate the sensor.Make sure this arm is in the correct possition and can swing up and backwards.Some time this arm get stucked against the body of the fax.It normally hapened when the upper cover of the fax was removed.
I believe you can fix this one, it is a relative easy fault
