My notebook will not power up at all. Have 2 batteries have tried with both. Have tried just plugging in without batteries and still will not power up. Light still stays amber. Please help.
SOURCE: Won't turn on
Try removing the battery and then plug it in. If it starts up put the battery back in it and try again.
SOURCE: HP NC6120 NOTEBOOK
click the link below. if it doesn't work copy and paste the code at the bottom of this post to obtain the document you need. you will need acrobat/adobe reader which can be found at www.adobe.com
once you open the manual the info you need is on page 11. it describes the steps to clearing any cmos info and bios passwords
product manual
http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=447346&targetPage=http%3A%2F%2Fbizsupport.austin.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fc00502970%2Fc00502970.pdf
SOURCE: On HP 530 notebook battery/power
Clarification of your battery/power led indicator:
Solid amber:
Battery is charging at 0% - 89% capacity
Solid green:
Battery is charging at 90% - 99%
Blinking amber:
Battery is low
Led is of:
Battery is charged
SOURCE: screen black but led lights on hp g71
It may be a hardware error. Call HP and see about your warranty.
A lot of HP's new laptops have hardware defects, which could happen at any time from the day you buy it. Have it sent in and have it repaired for free.
SOURCE: hp compaq 6715b...dos not turn
Test the adapter with another laptop in other to confirm if truly the adapter is still good. If the adapter works, then it means your laptop is having a power problem.
This has nothing to do with the battery because whether or not the battery is good or bad, that doesn't say the laptop shouldn't work with the adapter.
So the problem as to be either from the laptop's power board or from the AC adapter.
Tale care.
