When attempting to do a load i get a error code of OL the agitator ( nutator does not function . i can remove the bolt from it but it still does not move is ther somthing else i need to do to remove the nutator? The model # is 110.27087602 serial # is CT 3070431 type is 580 can you assist please? Thank You very much
What is a nutator?i found one time that there's a gear under the agitator that wears and the agitator doesn't move,remove the agitator and you'll see a part with 6 screws in it under that is the part you need to change part W10820039
go here and watch video
SOURCE: Kenmore Elite 110 does not spin/agitate/drain
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
The new outer tub with bearing W10128830 cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
http://media.fotki.com/1_p,srrtbrrfbdbqgkkxgtqsskgwtqkq,vi/bqkfstqqfxrqqbkwgqdxbwsqrwrtq/1/1303472/5961857/image828956817962821589img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
