Question about Intuit QuickBooks Pro 2007 Full Version (299116)
Can't Open QBs file after computer upgrade
My computer died and I now have a new one. The new computer has the version of Windows 7 that will run the older software that ran on XP (I had XP Professional). Of the two hard drives from the old computer, one is in the new computer. This is the drive where I stored all my files. The other one is unreadable, so I don't know what was on it. I have reinstalled QuickBooks Pro 2007, and tried to open my file. It says that I don't have access rights. I created a dummy file and installed all the updates, rebooted, and tried to open the file, but with the same result. I've tried opening the file both from within QBs as well as from the file itself, but with the same result. Any help will be MUCH appreciated!
  • Intuit Master
  • 2,075 Answers
No rights means that you have to share it or change its attributes (under win7).
Posted on Mar 26, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: Quickbooks Pro 2008 Payroll problem
Same thing here when attempting to "send payroll data", though mine's with pro 2009. I found this KB item which indicated that I should update:
http://payroll.intuit.com/support/kb/kbitem/1009052.html
I followed the update instructions here:
http://support.quickbooks.intuit.com/support/productupdates.aspx
Even though my update status was "nothing new" for each category, I hit the "Update Now" button anyway (it was enabled, why not?). It went through the motions of updating (even though there was nothing to update). When it finished, I closed and re-opened QB, then I was able to send the payroll data. This software is far from the gold standard I thought it was going to be.
Posted on Mar 20, 2009
eddiet20
eddiet20
  • 39 Answers
SOURCE: Problem reinstalling Quickbooks 2003 in XP Home
Here is step by step uninstall re-install instructions from Intuit, most likely quickbooks update caused the error, I suggest turning it off completely, there are a ton of users that have experienced problems with quickbook update service.
http://support.quickbooks.intuit.com/support/Pages/KnowledgeBaseArticle/1009651
Posted on May 28, 2009
Anonymous
  • 34 Answers
SOURCE: windows can't open quickbooks pro 2002
Are you receiving QB Program error or QB Data Error? What does error message say?
If your getting program error, get most recent patch at: http://sharedldfp.intuit.com/pub/quickbooks/2002/
If your getting data error, need more specific info. or try visiting: http://www.blocktax.com/quickbooks-errors.htm
Posted on Feb 02, 2010
SOURCE: I just downloaded QuickBooks 2010 EasyStart, and
You have to unistall the 2010 Simple Start program. It creates a conflict.
www.cpahispano.com
Posted on Aug 08, 2010
Chris Larocque
  • 367 Answers
SOURCE: I am unable to open
You may have to kill these processes before you do an uninstall / repair. Press ctrl + alt + del and select the processes tab. Find anything that says quickbooks or intuit. You could also look for the process ID's you posted. When you find them highlight each and press end process.
Intuit also offers this tool: QuickBooks_Clean_Install_Utility.exe
Regards, Chris
Posted on May 13, 2011
I updated BIOS from version P01-A0 date: 11/09/2009 to P01-A3 date: 05/05/2010, now getting CMOS Checksum Bad Press F1 to Run SETUP message and can only go into BIOS. HELP!
* what does it mean "not for upgrades"?
During the windows 7 to 8 transition, some PC models had different BIOS versions from factory, related to the installed OS.
Windows 8 PC got an UEFI BIOS
Windows 7 PC got a "Legacy" BIOS
So PC with Windows 7 installed from factory can't use the "not for upgrades" BIOS version, even if they were upgraded to Windows 8 or 10, since the factory BIOS was a different version compared to PC with Windows 8 from factory.
unzip the downloaded file, browse to WIN folder of the unzipped files and run the flash.bat file
Aug 27, 2018 | Acer Computers & Internet
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
Mar 24, 2012 | MGI Software PhotoSuite SE V4.0
Windows 7 will not recognise vdr-m70 dvd camcorder
Panasonic supplied software for the VDR-M70 for Windows 98 through XP on the CD. Due to changes in the OS over time, the installer can't run under Windows 7. Panasonic has not updated the drivers for Windows 7 and Microsoft indicates that it is not compatible with any version of Windows 7.
There are work-arounds depending on your version of Windows 7. If you have the 32-bit OS, try using the compatibility mode. To find out which version of Win7 that you have, click Start > Control Panel > System and Security > System. If the name of the OS ends with x64, then you have the 64-bit version of the software. Otherwise, you have the 32-bit version.
For the compatibility mode, right click on the installer on the CD (browse Computer). Choose Properties and then click on the Compatibility tab. Select Always Run this program as and an older version of Windows (XP). Apply and Save your changes. Then right click again on the installer and choose Run as Administrator.
This may not work (and won't work for the 64-bit Windows 7). If it doesn't work, you need a machine with an older version of Windows. This can be a second computer, a dual boot computer or a virtual computer (if your hardware supports virtual computing). For most options, you will need a licensed copy of the older version of Windows.
If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode from Microsoft in order. Then install the software for the camcorder in XP mode as if it were your only computer. (Of course this doesn't help if your hardware doesn't support the Virtual PC.) Other virtual computer programs are VMWare and Parallels.
Note: you can not directly share files or hardware between the Win7 and the virtual computer. You have to put files on an external drive (optical, flash drive or other external hardware) to share them.
I hope this helps.
Nov 12, 2011 | Panasonic Palmcorder VDR-M70 DVD Camcorder
Have photo imppression 6 can i upgrade it to run on windows 7
According to Microsoft it is compatible for Windows 7, you also can download supported updates packs from Window Update, it keeps you up to date. If you will face problem to use it after installing, please keep the following steps in mind:
  1. Do you get an error message?
  2. Do you remember making any changes to the computer prior to the issue?
You can try the following methods
Method 1:
Put the computer in 'Clean boot' and check the status.
http://support.microsoft.com/kb/929135
Note: When the troubleshooting is over do not forget to reset the computer to normal startup. Follow step 7 in the above article.
Method 2:
You can try to open the program in compatibility mode and check the status.
Make older programs run in this version of Windows
http://windows.microsoft.com/en-US/windows7/Make-older-programs-run-in-this-version-of-Windows
Open the program as an Administrator
Right click on the file and click on the 'Run as Administrator'
Jul 24, 2011 | Computers & Internet
New lap top is 64 bit computer but runs on 32 bit. program will not run
You will need to upgrade Windows to 64-bit. If you have Windows 7, usually there is a second disc for the 64-bit version. You can upgrade it without losing files. 64-bit programs can't run in a 32-bit Windows enviorment.
May 19, 2011 | Rand Mcnally TripMaker 1999 Full Version...
I purchased a business card maker softwarde CD The files are BCD. I have just upgraded to Windows 7 with my new computer and it is telling me that the software that I have been using isn"t...
Unfortunately many programs did not upgrade their software when windows 7 came out. However, there is something called XP mode in windows 7 which emulates an XP environment. You can install it by following these instructions: http://www.microsoft.com/windows/virtual-pc/download.aspx. With it you'll be able to do anything you could in XP including access these files in question.
May 11, 2011 | Computers & Internet
I could not install PrintMaster Publishing Suite 7.0 on our new computer running Windows 7. Is this software compatible with Windows 7? Is the a version to upgrade to that is compatible that we can work...
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Jun 20, 2010 | The Learning Company PrintMaster...
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
Jun 10, 2010 | Microsoft Windows XP Professional for PC
Can i convert a 32 bit to a 64 bit
You can use the Upgrade option during Windows 7 installation, which preserves your files, settings, and programs, only if you're currently running a 32-bit version of Windows Vista and you want to upgrade to the 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only perform an upgrade to a 64-bit version of Windows 7. For more information, go to Upgrading to Windows 7: frequently asked questions on the Windows website.
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows 7 or vice versa, you'll need to back up your files and choose the Custom option during Windows 7 installation. Then, you'll need to restore your files and reinstall your programs. For more information about performing a custom installation, see Installing and reinstalling Windows 7‍.
gl_ico.png Notes
  • To install a 64-bit version of Windows 7 on a computer running a 32-bit version of Windows, you'll need to start, or boot, your computer using a 64-bit Windows 7 installation disc or files.
  • If you start your computer using a 64-bit Windows 7 installation disc or files, but your computer isn't capable of running a 64-bit version of Windows, you'll see a Windows Boot Manager error. You'll need to use a 32-bit Windows 7 installation disc or files instead.
  • Windows Easy Transfer can't transfer files from a 64-bit version of Windows to a 32-bit version of Windows. If you're running a 64-bit version of Windows Vista but you plan to install a 32-bit version of Windows 7, you can move your files to an external location manually or use Backup and Restore in Windows Vista. For more information, go to Back up your files and
Apr 08, 2010 | Dell Precision Workstation 490 - MT -...
Intuit QuickBooks Pro 2007 Full Version (299116) Logo
74 people viewed this question
Top Intuit Computers & Internet Experts
NET MAN
Level 1 Expert
Ekse
Dalynn Turner
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
