Press the Playback button (the right-pointing triangle). Press the MENU button. Use the cursor buttons to select "FORMAT."
If you need a manual, you may download a copy here.
SOURCE: memory card locked
There is a switch on the SD memory card, slide the switch to unlock position before you insert the card into your camera.
More detail, see here How to fix a ‘card locked’ problem
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
SOURCE: memory card lockes on my panasonic lumix
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
SOURCE: Uploading MTS files from the Panasonic Lumix DMC-TZ7
Are the videos in AVCHD Lite or Motion JPEG? Most computers can't handle AVCHD.....most of the time, you can only play them on an HD tv.
SOURCE: windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
