How to get to the thermal fuse?
It is located on the rear bulkhead upper right hand corner. Ti access it you pop the top with a putty knife and remove the front panel. Get the drum out. I recently worked on one and did a video:
http://www.youtube.com/watch?v=wkog1i53T_k&list=UUKBjalPycKRmo4Mz9vRsydg&index=10&feature=plcp
http://appliancejunk.blogspot.com/2011/08/frigidaire-gallery-dryer-revamped.html
The smaller disk is the fuse. If blown the dryer will not run
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: where can i find the thermal fuse location on a
Open the top lid and look in the back right corner.
With a model number I can be more specific.
SOURCE: noise in dryer Frigidaire model fde336res1 when running
Could be the drum bearings are worn. These are what the dryer drum turns on and when they wear out the drum and frame rub together (metal to metal). Also could be the belt idler which keps the belt tight around the drum. In either case the dryer would have to be internally accessed to determine failure.
Testimonial: "thank you. I will call repair man."
Good Afternoon friend, thanks for your post!
I understand that you are searching for the thermal fuse within your Frigidaire dishwasher, FFBD2411NS. I checked over your parts manual and was unable to locate any thermal fuse. Is your dishwasher not heating up? What issues are you having with your dishwasher? Any further information and I would be able to assist you further. -Matt
Hello April Tucker - Generally speaking, Frigidaire laundry centers do not have fuse. The unit has a thermal limiter usually located in the dryer.
