Hi, my OKI 390 FB printer stops while printing. I had tried to completely unplugging and reinserting the cord into the power outlet but it dint work. When i print windows test page it will print completely, only if i print other documents like oracle system documents, printing will stop and alarm light blinks. Then there is no paper jam and cartridge problem. please advice
SOURCE: Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
First, reinstall the driver and be sure it's the correct driver for this printer. If you drive a word document does it do the same? If not, chanses are the db application is constantly sending form feeds to the printer and the printer will do whatever it's told to do. Try a different printer setup in the db application.
SOURCE: I need to know how to print a test page on a Oki
Try Select, or Shift and Select, or Shift and Print.
See reference manual in here.
SOURCE: i have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
SOURCE: oki microline 390fb alarm blinking,
There are a few things that are possibly wrong with your printer. You may want to try completely unplugging and reinserting the cord into the power outlet. If that doesn't work, check your printers ink levels and ensure that there is no paper jam. Best of luck.
hi, how can find out what is the error blink means.
regards
