I have asus RTG32 Router Problem is My neber also connect wifi throw my internet for free thats y my internet speed is too slow pls tell me to how to close it setting tell me pls or call me 8888225222
SOURCE: My asus rtg32 is not
even i am facing the same problem,did your problem solved out buddy??
thx'
shubham
SOURCE: Hi, I have got RTG32 router
Do you use a username and password provided by your ISP on the computer to connect to the internet? If yes, these need to be entered into the connection settings of the router. Are you connecting the internet line to the WAN port on the router? Did you install to your computer the ASUS utilities? Try the EZ Setup utility. You can download the manual from this link http://www.asus.com/product.aspx?P_ID=gEbdYWdf5mjkJUKc
SOURCE: i cant open my WIRELESS
Hi!
I tried to figure out some explanation, and I think it's possible that both WAN side of the router and LAN side of it have same types od ip adresses, maybe the default 192.168.1.***. That means that the WAN port of the Router, the ethernet port of the modem, the wireless and LAN ports of the router have same tuype of adresses, maybe all asigned by DHCP.
To be sure, I suggest you to:
1. turn of the modem
2. check that the network connection obtains ip adress automatically
3. in a dos prompt (START - RUN -CMD) type IPCONFIG, it will return among other infos the adress of the default gateway.
4. now type that adress in the browser.
5. if it works, log on to the router and change the LAN settings so that the adresses used in the LAN will be different from the WAN, let's say 10.10.10.1 and so on
