Is all small amount of oil is coming out somewear,but the generator work fine,only that problem.how I fix that thanks
There is a lip type seal on the crankshaft that is likely damaged. In order to get to it, the generator needs to be removed completely.
If the small amount of oil is just an annoyance you can live with, leave it be. The oil should be changed on those frequently, and if you run it in hot weather use a heavier straight weght racing oil. In the US and those areas where the US designations are known- SAE 30 W is best and change oil after 10 hours of operation. It may seem too often, but it is about the same interval of oil change as the cars had back in the days when they were not equipped with an oil filter.
