I have two similar projectors in my XD movie theater. One of them started to show white dots scattered on the screen even when the PC is off.
SOURCE: viewsonic projector pj501 - Has purple bloch with
2 issues- the light filter on one of the lcd panels is burnt due to excessive dust and heat. and one of the lcd panels is shot. time to replace the entire optical engine, unless you can get the prism assembly. otherwise, replace the projector. if you do, remember to keep it clean.
Testimonial: "Thanks for the help. Looks like the trash for this one!"
SOURCE: Settings on ViewSonic PJ513D Ceiling Mounting
The user's guide says for ceiling mounting,
"Set Front Ceiling in the System Setup: Basic > Projector Position menu after you turn the projector on."
The user's guide is on the CD included with the projector as a pdf file. You can also download the user's guide here:
http://www.viewsonic.com/assets/006/5619.pdf
If you find this solution gives you what you needed, please take a moment to rate it. Thanks for asking here!
SOURCE: Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
SOURCE: dvd player to projector
Yes please.
You can connect it either thru the RCA Composite output(yellow) of your DVD or thru the S-Video or even thru the component out(YPbPR) connections. In the component out you would require three RCA cables and would give you the best possible picture.
Find a link below , which gives a review of the Viewsonic PJ 501.
http://reviews.cnet.com/home-theater-projectors/viewsonic-pj501/4505-7858_7-20722971.html
Hope this clarfies.
Please do rate this solution and thanks for using FixYa!
