If the security light is blinking.... turn key on try to start truck let the key go and it should leave all the dash lights on wait about 10 minutes til the security light goes off then turn the key off and then try to start the truck again repeating the process three times . no more than three. on the last time the security light goes off turn the switch off and it should start the process is called the ''10 minute relearn''.
SOURCE: How to reset factory alarm in 1997 Chevy Suburban without a keyfob
to disarm the factory alarm try unlocking driver door with the key. does it blow the horn or does it have a siren?
CAR ALARM ISSUES
It
can be any of the car doors not got properly locked or the door is locked but
the switch is not sensing the door locked. Open and close each door again
properly.
Or
else its problem with any of switch wiring getting in contact
with alarm wiring causing it to happen.
And
last thing alarm connections need to be inspected. It's getting short somewhere
in between.
There
are few help links with solutions, to troubleshoot these types of problems.
I suggest going through these links.
Click
the link below: ------
http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
These
details will help.
Thanks.
It
properly.
Or
And
in between.
There
Click
These
details will help.
Thanks.
What terminals under the dash do I need to cross, in order to reprogram my remte entry -alarm device 3 Button 1997 Chevy Tahoe?
