Question about Sony BRAVIA KDL-46W3000 Television
Thin green verical line in lower right hand corner of LCD TV
I ahve a Sony Bravia Model KDLV40XBR1 LCD TV. In the past few days I have noticed a thin green vertical line. I have an extended warranty through Tweeter but, of course, they have gone out of business. Sony is will to send a tech out but I have a feeling I will have to pay for repairs. Any suggestions? Thanks so much.
  • Anonymous May 13, 2009
    green line of tv visio lcd
    Master:
  • 313 Answers
Either the cable or a connection from the processor to the screen is not making contact. If it is just a cable connection, that can probably just be re-seated. If it is a problem on the board, it probably is not worth it. Find out what their minimum charge and their hourly rate is, then see what a new TV costs. You will probably get a new TV instead.
Posted on Nov 29, 2017
  • Sony Master
  • 2,800 Answers
I would bet on it being a panel issue, you can try a new t-con but I don't think its going to correct it, may be time to buy a new set
6ya staff
SOURCE:
Anonymous
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
Jim Krause
  • 1779 Answers
SOURCE: my plasma has a thin black horizontal line
You can either have a bad Y-Upper buffer board, or dirty contacts on the plug associated with the horizontal line. Best to have a service company look at it.
Posted on Jul 24, 2009
Anonymous
  • 131 Answers
SOURCE: My Sony bravia 40
other than a software upgrade. it probably a graphics chip malfunction and will need replacement.
These can be replaced but costly. Does it do the same if you use screen as a pc monitor?
AndystUK
Posted on Aug 31, 2009
vinnyq
vinnyq
  • 157 Answers
SOURCE: Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Posted on Oct 05, 2009
Testimonial: "Thanks for the response. The service company Sony recommended told me it was probably the screen, too, and they quoted $1000."
roety
Eric Rotmil
  • 587 Answers
SOURCE: thin vertical line runs across the top of screen
Hi my name is Roety,
I can help you with your issue ,
 Try the format, aspect buttons on the Box remote, if the line is there on every input and effect the TV menu your panel (screen) is bad.
A new panel would cost as much as a new TV.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Oct 24, 2009
Thin green vertical lines
if its only one channel its your cable service, if its constant try unpluging your tv from the wall for 30 seconds to reset it, also try reconnecting any AV cables for the source you are using, If you are using a Coaxial cable unscrew it and check to see the copper needle is not bent or damaged.
Dec 19, 2013 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My sony bravia 32" is
hi ;
there's a problem in screen driver of your LCD, if you lost your receipt,that's bad luck.
if you know how to disassemble the back case of the TV , you can try some RESETTING of connectors from LCD screen driver to display driver board
its only 50% chance to remove the line.
thanks.....
Sep 11, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
52" Sony Bravia TV has a thin Blue line down left
A line on an LCD screen can be cause by the screen itself going bad or the T-con board. The T-con board the attached to the screen on the backside and covered by a heatshield. If you get teh part number from it you can find it online from one of the many retails that might have it. Like www.interliquidparts.com
Jun 06, 2011 | Sony BRAVIA KDL-52XBR4 LCD TV
The top half of my Sony Bravia 32" screen plays as
I'm sorry, it sounds problem with lcd panel (screen) that is defective and causing lower half distorted image. If tv is under warranty then call number written on warranty documents for warranty cover or lcd panel (screen) replacement would cost you approx 80% of new tv price.
Hope these info will help you.
Thanks.
Nov 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Line thru screen
The LCD Panel must be replaced to fix both problems. The cost in doing this would exceed the value of the set. I recommend not putting the money into it.
Skyassoc
Nov 25, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Oct 05, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Thin vertical line
You are going to find it is a LCD panel problem. I am sure that they will take care of you. But also realize that this could have happen to any brand of LCD panel and you will probably not have any other panel issues once it is fixed.
I feel your pain,
Skyassoc
Jun 21, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a Sony Bravia KDL-32v2500, 16 months old, a thin vertical green line has appeared just off centre. It is on all channels and all input sources. Any suggestions?
If it still under warranty, no cost will be there, but if its out of warranty, you have to pay to Sony (might be they give you some discount) because its problem in LCD Panel.
Aug 05, 2008 | Televison & Video
Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Aug 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-46W3000 Television Logo
509 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
