Try this:
1. Remove All HP files that were installed before 'fatal error' using 'Printer Util.exe' or similiar file available in HP CD.
2. Install software 'Dial-A-fix'. (Dial-a-fix is a collection of 'known fixes' that have been compiledover the past year that really knock out some serious Windows problems....)
http://www.download3k.com/DownloadLink1-Dial-a-fix.html
3. Run the 'Dial-a-fix.exe' Software and select 'Fix Windows Installer' & 'Empty Temp Folder' options and click 'Go' button.
4. Restart your computer, run the HP CD, you should have no problem. (don't connect the printer/device until the HP Setup prompts you to)
Hope this helps, amit b./india
SOURCE: error message fatal error during
make sure its compatible with computer before installing because you computer need to recognize the printer after you pluged the printer with computer
I keep getting the fatal error during install. I am trying to reinstall from the driver/software page at HP. Very frustrating!
