After playing a song it shows file name error
SOURCE: MacBook Intel and GPX MP3 Player
The GPX MP3 Player will not recognize .m4a files. You must convert the files to MP3 files first. To do so, in iTunes, click "Edit, Preferences". Change the tab to "Advanced". Inside, there should be a second tab control. Change that to "Importing". Change the "Import Encoder" to "MP3 Encoder". Close those windows. Select the song you want to convert to an MP3, right click, and choose "Convert selection to MP3". Then, locate the file that was created, and put it on your GPX. If you want to convert your entire library, just select all files using Control+A.
SOURCE: Transfer songs to iTunes...
While the Mp3 is still connected, Save the songs to a playlist. Then, take the Mp3 out.
SOURCE: Can't see songs on GPX Mp3 player
what operating system is your computer.XP is the operating system recommended but you need windows media player 10.If you have them both you can move/sync files thru Windows Media Player(WMP) but they have to have a drm licence.
If you've got Windows® 98SE, ME, or 2000 Professional.
5 just connect it, find My computer and you should see the player listed,double click and the files should be visible.
I would check your friend's operating system to see what he/she used and if any problems occurred.
MTP” mode will only work, when your player is connected to Microsoft® Windows® XP and Windows® Media Player 10.
The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional.
5
