SOURCE: when I zoom useing my panasonic lumix DMC-FX01 it turns off
Have you had problems when you turn it on and off from scratch before? It sounds like you have a problem with the lense extension. Now if you are lucky, it's just a bit of dirt in there and the best cure (I know, it sounds horrible) is to put the end of a shop-vac over the lense when it's closed and it will probably **** the obstruction out. If you are less lucky, the problem is with the gearing inside and in the middle of the luck-vs-effort range it could just have been bashed, in which case, you can try and push it back into alignment but be careful with it (he says, after he hit his last one with a large lump of wood to put it back).
Good luck :)
SOURCE: changing DMC-ZX1 language from Japanese to English
Just go into the menu and scroll to language and select English.
SOURCE: DMC-FZ7 Panasonic digital camera won't focus when zoomed
Your camera focus problem mostly deal with machanical parts. So changing them easily will solve the problem. But unfortunately you may not do it yourself. Because it is highly complicated process. In deed it needs lots of repairing devices which are found only in services. According to me the service had given you the best answer. Please accept their advice. Good luck.
SOURCE: I need to transfer photos from my built in memory
Select "COPY" from the PLAY menu. Select the direction (in this case, IN-to-card). Select YES.
SOURCE: how do you change the language settings on a
Language should be the second-to-last item on the Setup menu.
