I bought my player in September 2002, and have had no problems until recently. But now, many discs that previously worked fine, no longer do so. They spin for a while and then the unit displays 'error'. I recently bought a dual disc, and while the 'CD' side plays fine, the DVD side will not. I have tried these discs in my pc DVD and they are not faulty discs. Any help would be appreciated. Thank You, Nigel
Well, seems like your laser diode is getting old. you need to change the diode. what you are experiencing is the start of a dying diod. it will start to rejects cd and soon enough it will not spind at all on all the cd's. so change the emitting diode. good luck
Was this player playing previously? And
how long have you been using this player? I suspect the lens of the
player. Once the lens of the player becomes weak, it won't play discs
any longer.
The first thing my mind goes to, is the lens. The
lens id responsible for reading/loading data on discs. So if the lens is
unable to read the disc, there is no way the player is going to play
the disc.
To confirm if actually its a laser problem, insert an
Audio CD into the player and see if will play. If it plays, then
obviously, your laser (lens) is weak. But if it doesn't play Audio CD,
then it might still be the laser (lens) or probably, a mechanism
problem.
Get a lens cleaner, use it to clean the lens. If that
doesn't solve the problem, get a screw driver, open the player's cover
so that you can gain access to the lens, use a cotton board to clean the
surface of the lens. This should clean dust or dirt that might be on
the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To
replace the lens, remove the bad laser, use it as a sample to get
exactly the same type and do the replacement. Note that replacing a
laser (lens) needs a professional touch, so if you cannot replace the
laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
If you have purchased multiple dvd players and none of them will play your DVDs (including your old player which previously played the old DVDs), then your issue is with the DVDs. You have to replace them because they have been damaged or scratched and can't be read by the laser anymore. DVDs are not indestructible and can eventually be damaged beyond repair. You'll have to replace the DVDs, which makes more economic sense than buying multiple DVD players to try and play them. If these are home movies or personal recordings you should contact a local computer store about data recovery.
The dvds discs u bought from the UK is play on only the DVD player that play PAL signal format. Where u live Canada,US or Mexico?DVD players in these countries.It play only NTSC signal format.U can't change DVD players regions format,only can a DVD players that have regions free to play all DVDs discs of the world.
We have had out Toshiba P25-S509 for a very long time. It's a great laptop and watching DVDs with a wide screen was great; That is, until the CD/DVD player was no longer recognized by the computer. We took it in (still under warranty) to have it fixed, only to not work again after a couple of months.
Now YEARS have gone by and I have bought another Toshiba (M305D-S4831) which is great unless you try to reboot and it doesn't fully start up. That's for another review, not this one... So, back to the P25-S509 and YEARS later. We just received two 1GB memory cards, which are being used to replace the "stock" two 256 MB memory cards. Well, the computer is MUCH FASTER and THE DVD PLAYER FINALLY WORKS!!! Woo-Hoo! $98.00 investment in memory cards saved up from ditching the older Toshiba.
Hope this review helps someone out there that might have had the same problem.
I have the Denon 2900 (about 4 years of use) and until recently, suffered from the same (growing) problem. CD's were very difficult to start/read. I recently found advice which I tried and was succesful with. It was manually cleaning the laserlens. I took away the outer housing by unscrewing all off the on top (6), side (4) and the back (2) bolts. After that I took out the top plate of the laserunit which took two very little screws taking out. Now you are looking at the cd-tray with the lens. Take a very soft and clean cloth and moisten it a little bit with clean water (be very carefull with the moistening, don't allow any waterdrop to come out of the cloth into the laserlens while cleaning! Carefully clean the lens and dry it with a dry part of the same cloth. Replace the top plate and the outer housing and the player will recognize the discs like it's new again. Good luck! Robert Jan, The Hague the Netherlands
So, how does one change the diode? Can I buy the replacement part? where?
