General Electric Universal Remote Control Logo
Monique Gallant Posted on Jul 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a code for my digistar tv to programme my bell expressvu dish
Level 3:
Top Expert:
  • General Elec... Master 76,851 Answers
  • Posted on Jul 10, 2012
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986699
Points
237762
1019 0165 0118 0116 0167
4 Related Answers
Anonymous
  • Posted on Oct 25, 2008
SOURCE: Codes to program Innovage Products Jumbo Universtal Remote
H have the jumbo universal remote from innovage pruducts. can you e-mail me all the codes? thanj you. [email protected]
Anonymous
  • 2071 Answers
  • Posted on Jan 28, 2009
SOURCE: need remote code for programming a bell expressvu receiver
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
Anonymous
  • 56 Answers
  • Posted on Nov 12, 2009
SOURCE: bought a dish identical remote to Bell Expressvu.
You may need to program to your equipment, go to dishnetwork.com/tech and that will show you how to address your remote.
Anonymous
  • 358 Answers
  • Posted on Apr 13, 2011
SOURCE: i need a code number
I have provided instructions on programming the remote to your Dynex TV. I have included the codes for your TV. We do not have codes for the Universal remote. You need to contact Phillips to see if they have codes that you can use. I hope this helps.
Address remote to TV:
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote codes: 720, 115, 969, 111
Ray Calo
DISH Network
I need a code number for a DAENYX TV ihave a remote philips brand number sru5107/27 All so will the remote for bell expressvu work for for HD expressvu the remote belongs to model 3200 express vu
Ray Calo
DISH Network
I want to program a Dish Network remote to run my Bell ExpressVu receiver.
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. While looking through all of our remote codes I unfortunately did not find any codes for a Bell ExpressVu receiver. What you can try is running a power scan on your DISH remote which basically can sometimes find the code for you. I will list here for you the instructions for running a power scan after this post. I hope you find these instructions useful and if you have any further questions or concerns feel free to email me at [email protected]. :)
Instructions for a power scan
  1. With the desired equipment on, press and hold the correct Mode button (i.e. SAT, AUX, TV, VCR) until all mode button back lights illuminate, then release.
  2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
    • Press 0 for a TV
    • Press 1 for a VCR/DVD
    • Press 2 for any other device.
    Then Press STAR (*)
  3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
  4. As soon as the desired equipment turns off Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
5helpful
3answers
I need a satellite Bell express Vue code (3100) I can't use the remote control Dish!!!!
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
1helpful
2answers
Codes for Digistar TV
code for remote filips
Bought a dish identical remote to Bell Expressvu.
Programm bell expressvu 4100 remote control
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia with the bell remote. Hold tv button till all 4 lights light up and then press 660 # and everything (minus the menu option) should work. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
Need remote code for programming a bell expressvu receiver
JVC DVD 0558, 0623
Regards,
VOTIT
11helpful
2answers
Replacement remote for bell expressvu
Here is the link to pdf document: http://www.highspeedsat.com/pdf/satellite-tv/expressvu/remote.pdf
Top General Electric Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a General Electric Televison and Video Expert? Answer questions, earn points and help others
