Hi Philip,
To answer your question, from a single TX/RX device (your WiFi unit) to a dual antenna, what you would need as a splitter is more commonly called a "phasing harness".
A phasing harness is a balanced transmission line which is used when you want to stack or use two antennas from a single radio output. In lower frequencies it is made from a pair of 75 ohms high grade coaxial cable of equal odd quarter wavelengths of the operating frequency. The joint at the middle is connected with a “tee” connector with another cable (standard 50 ohms cable) that runs down to the radio. The free ends of the 2 75 ohms coax are then connected to the two antennas. This
site shows phasing harness for multiple antennas.
For microwave region, since losses tends to be magnified, commercial grade are often used rather than home brewed. Examples are shown in this
page.
Alternately and perhaps simpler is to just remove the reflector of the 8Dbi patch antenna of the EOC 3220. Normally in designs such as the 3220, the active patch antenna is soldered on one side of the PCB. At the back is another which looks just like it but slightly bigger. This is the reflector. The reflector has two (2) purposes:
1. block any signal coming in from and going to the back of the active patch antenna; and
2. reflect any back signal of the active patch antenna and re-direct it forward to effectively increase the front signal.
If you decide to remove the reflector, there will be 3 effects on the performance of your TX/RX device:
1. the front (major) lobe (roughly the front radiation pattern; maximum distance and area covered of the front signal traveled) will be greatly reduced;
2. that reduction would be translated to a rear coverage; and
3. it is highly possible that you will have small side lobes as well.
This
document would give you an idea on the lobes and radiation patterns.
Good luck.
