If you are looking at the back of your tv there is the stand bracket with a screw on each side. remove those screws and nothing will happen. that is the problem i was having but if you look right above the ones you just took out and there is going to be a black screw. take those off from each side and it will fall off.
My problem was I put on the wall mount on the tv before removing the stand. Turns out the top two screws that needed to be removed to remove the stand was under the wall bracket mounted on the tv. I removed the wall mount bracket and found the screws. I felt pretty stupid.....
I can not remove the tv stand so I can mount the tv on the wall.
