I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Testimonial: "Thanks i took the tv apart and got to the color. When you spin it with your finger it should spin for a bit correct? Mine spins for about half a second."
I replace color wheel and the chip know i have the control light blinking one red and 7 yellow
please i need help to know how to fix it thank you
My bulb went out. I replaced it then a couple days later it started flickering. I bought another color wheel it worked for an hour then stated doing it again. It makes a notice when this starts flickering like a humming noice
SOURCE: Projection tv flashes green and purple tints
Find your reciept then call mitsubishi . if you purchased it less than 3 years ago mitsubishi will pay to have the expensive light engine replaced.
SOURCE: blue screen with flickering horizontal lines
Sounds like the 1000uf capacitors on the FMT board need replacing. This is a common symptom with that chassis. There are three 1000uf caps that fail on that PC Board
SOURCE: I have Mitsubishi WD-62525. Last
that is a common problem with that model you will need the v26 power pwb repair kit and the V26 FMT pwb repair kit. You can get both kits at the following link which includes the replacement capacitors and instructions on where the capacitors are located. Heres the link.
http://servicemanuals.vstore.ca/
SOURCE: no picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
Also there is a tick noise in the back
and also the shuts off after about 5 min of flickering
UPDATE: Replaced color wheel and still has the same issue
