SOURCE: Can the LG Electronis LWHD1500ER
I don't believe that this unit can be mounted in a through the wall application. My database does not show a wall sleeve for this unit. The biggest reason will be the side vents for the condenser heat exhaust. I would stick to the manufacturer suggested window application.
SOURCE: can I add freon to a Goldstar window air
Donna, Freon is no longer used. In it's place it's R134a Refrigerant. But, in most cases, this is not a DIY project. As , specialized equipment is required to evacuate the system, before new refrigerant gas can be introduced into the system. In addition, pressure gauges are required to make sure that it's not over filled or under filled.
If you have all the proper equipment and the knowledge, go for it. If you don't, it's best left up to the pros.
Hope this helped you. Please let me know. Thanks.
