Question about Whirlpool AWM8163 Front Load Washer
On my whirlpool awm8163 the door will open after a cycle and door open light is off
6ya staff
SOURCE:
Anonymous
  • 14 Answers
SOURCE: Whirlpool Fron Load washer. Can not unlock door.
There is a manual way to unlock door. I copyed this from the tech sheet.
Manually Unlocking the
Door Lock System
1. Unplug the power cord from
the outlet.
2. Remove the lower kick panel.
3. Reach up along the inside of
the front and locate the bottom
of the door switch/lock unit.
4. Located on the bottom of the
door switch/lock unit is a
tear-drop shaped tab.
5. Gently pull the tab down about
a ¼” or until a click is heard.
6. The door may be opened.
Also there is a test procedure you can run to check the door lock actuator.
DIAGNOSTIC TEST
The washer must be empty and
the control must be in the OFF
state before pressing the
touchpad sequence to start the
test.
Starting the Test Mode
 Close the door.
 Push CONTROL/ON (if present on
this model).
 Select the DRAIN/SPIN cycle.
 Select NO SPIN by pressing the
SPIN SPEED touchpad.
 Push PREWASH OPTION four
times
within five seconds. (If
PREWASH OPTION is not present
on this model, press RINSE HOLD
four times within five seconds.)
C:00 will light up on the display.
Hope this helps.
Posted on Dec 09, 2008
Anonymous
SOURCE: F11 error
The F11 fault is the motor. I have had this issue myself and found that replacing the contact brushes solved this. The brushes on most electric motors are made from carbon, and wear down with use. They are spring loaded but have a limited life span. These are also cheap to purchase.
Posted on Feb 08, 2010
Anonymous
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
Anonymous
  • 58 Answers
SOURCE: whirlpool AWM6100 front loading - door open when not!
it's probably the innerlock, is the door locked?? if not it could be the innerlock
Posted on Mar 09, 2010
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Whirlpool AWM6100 frontloader, during cycle
Door Interlock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 28, 2010
I have a whirlpool sixth sense washing machine. the door open light constantly flashing although the door is well shut. No programmes work
We had the same issue: the cycle would start then stop, with the door open light coming on. It turned out to be a faulty contact in the door. Took a technician 15 minutes to fix.
Aug 04, 2011 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM6100 front loading - door open when not!
Mar 09, 2010 | Whirlpool AWM6100 Front Load Washer
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
F11 error lights flash then stops at last spin . I did clean the filter and took some coins out Whirlpool AWM8163 washer
Jan 23, 2010 | Whirlpool AWM8163 Front Load Washer
The code is F09 or FA I can not change it i tried to drain it but still will commence a cycle then F09
try pushing the pause/cancel button twice to clear the display. you may have a foreign object in the pump.
Oct 25, 2009 | Whirlpool AWM8163 Front Load Washer
Washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool AWM8163 Front Load Washer
The machine runs until the spin cycle then stops
That means that you need to have the door latch replaced, a bad door sensor is preventing the washer from spinning.
Try first unjamming the latch with a stick, like a pencil for example.
If that does not work, replace the door latch.
Mar 30, 2009 | Whirlpool AWM8163 Front Load Washer
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
Spin
Electrical module fault
The “Spin Speed” indicator and the “Start
Delay”
option are flashing and an audible tone
sounds. The display shows “F4” to “F16”.
Switch off the appliance. Select a programme
and press the “Start/Pause” button once
again.
The programme will continue.
If the fault re-occurs, contact After Sales
Service (see “After-Sales Service”).
the user man can be found here
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001
Jan 15, 2008 | Whirlpool AWM8163 Front Load Washer
Whirlpool AWM8163 Front Load Washer Logo
69 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
