Question about Ricoh Aficio BP20 Laser Printer
Test page of my RICOH MP C3502 did not print
The status says the printer is offline, has the document not sent to the printer.
2 Suggested Answers
6ya staff
SOURCE:
Derek
  • 68 Answers
SOURCE: Our Ricoh MP 171 devices go offline after one
have you tried doing a local connect using a crossover cable to the printer to see if it is the printer or the 2k3 server?
I have seen this issue when terminal services are enabled on the server.
if when you connect locally to the device using x-over it still does it it may need to have the nib firmware updated, however if it doesnt I would run a packet sniffer on the network jack that the device is plugged into and check to make sure that the port is good and transmitting and receiving all packets check the network cable and replace that and if all else fails try the device on a different network port.
Posted on Sep 16, 2009
POwer botton flashing light.. cant print and the status is offline.. how can i fix this problem pls help
The flashing light is because the printer will not print if it's offline. Be sure the printer is connected to the Internet. It may be offline because you have tried to print too many documents. If that's the case, you will need to delete all the documents that have been sent to the printer and haven't printed. Don't delete the actual document from your computer, but from the print queue. Hope this helps.
Nov 20, 2017 | The Office Equipment & Supplies
The Brother MFC-7840W printer was installed on a USB connection. The printer worked the previous week albeit not for all applications but at least for the Vista word program. Now it doesn't respond to...
Hi there!
You can check if the usb cable is connected directly & securely from printer to your computer. Once it's verified. The display of your printer should show the date/time.
Since the printer is displaying offline you can open Control Panel, go to Printers folder right click on the printer icon and select 'Use printer online' If you have pending documents right click on the printer icon and click on cancel documents.
Try checking for a duplicate copy of your printer driver or check which printer driver is selected as the default and has the status ready.
Right click on the printer driver that has a Ready status click on printing preferences and click on print a test page.
Hope this helps! Vikroks
Mar 22, 2011 | Brother MFC 7840W Printer
Printer is online, but status is offline
Hi, make sure if the pdf you can't print is restricted by owner password which prevents you from copying, editing and printing pdf files. User a pdf password remover to remove pdf password. AnyBizSoft has a product like this.
Jan 15, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Same Problem - Printer Says Offline
try reinstalling all drivers,, and cancell all prints. before.. take an test print from , control panel ---printer-- print a test page..
Sep 27, 2009 | Brother MFC-410CN All-In-One InkJet...
Printer status- error offline
first go to services.msc refresh the spooler service. then insert the printer disc in to the computer . do a level 2 uninstallation .
restart the computer then again again reinstall the software issue will resolved
Aug 03, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printer Connected but wont print
- go to printers folder then check the status of your printer - if it is offline, right click the icon and select use printer online...
- check if there is pending documents becuase printer wont print if there is pending document in queue- to clear the pending docs. right click the icon and select cancel pending document
- printer OJ 5610 icon should be in ready status, no pending documents, and the icon has a checkmark as as default printer...
Nov 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Photosmart 2575 printer is offline - won't print
In Vista make sure you are logged in as a administrator whenever you make any changes.
And if not to bring the printer online you will have to right click on the printer icon and right click on Run as administrator> and then try bringing the printer online and checdk if it works.
And you can delete the Microsoft XPS Document writer it is a default printer icon installed if in case you did not have a printer installed you can store them to print later.
Now that you already have a printer you can delete the Microsoft XPS Document writer.
Good Luck
Oct 02, 2008 | HP Photosmart C7180 All-In-One InkJet...
Printer stating it is offline when I go ito printers
hello..!
- here are the steps to check if your printer is ok:
- goto control panel then printer and faxes folder(XP) or printers folder(VIsta) then click that folder and you can see the icon of your printer. when you point that icon it will view the status of your printer if the status is offline then right click the icon and select use printer offline. then make sure that therer is a checkmark on that iocn and no pending document.
-- hope it will help to solve your issue
Jul 28, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Good Day,
One thing you can try instead of deleting the doucment writer is to change the default printer. You can do this by right-clicking on the HP printer icon and selecting "set as default" from the drop down box. Also try turning the printer off and back on aswell as restaring the computer if you have'nt already. Did that printer ever work from that computer? How is it wired, by "switcher" do you mean a shared printer through you network(was printer sharing configured properly), or an A-B printer switch. Please clarify
Hope this helps for now
Jul 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
How to change "offline" status to "online"
Assuming you are on a PC:
Go to your control panel in Windows, open the printers box, choose your printer by double clicking on it, then click on 'printer' on the left edge of that window. Scroll your mouse down to where it says 'use printer offline' and uncheck that option. This should release any documents you have waiting in the queue.
you will also need to check your manual on how to set its sleep function, as some printers like to go to sleep really quickly - and that causes Windows to think it is offline.
May 21, 2008 | HP PhotoSmart C4280 Laser Printer
Ricoh Aficio BP20 Laser Printer Logo
91 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
