Maytag MDE6000AYW Intellidry. One paddle is loose with one screw off. I need to know how to take off top panel or back panel so I can get to drum and screw back in the drum paddle. I have looked at parts
Two of the three paddles have fallen off. Is there a way to either raise the top or take off the back panel so I am able to get to the drum and screw the paddles back on. Thanks!Two of the three paddles have fallen off. Is there a way to either raise the top or take off the back panel so I am able to get to the drum and screw the paddles back on. Thanks!
Take the four screws, out of the door and remove it. The front of the dryer will fold down and lift off, you will be able to see in side the dryer. If you want to lift the top remove the screws that are now exposed. Along with the brackets the top will now lift up.
remove 4 screws around the door perimeter,remove door,then the front panel will pull off towards you then remove 2 hex headed screws just under where the top and front covers meet,then you can raise the top to replace baffle/paddle screws
Is blade loose or broken off? Either way, you must remove front panel (door panel) to expose the front drum end retainer brackets, which you must unscrew and remove to get at screws to tighten or replace missing paddle blade. You can get replacement part at www.repairclinic.com their very reasonable
take the 2 screws out of the door and take out the other 2 screws opposite the hindge screws,close the door,now grab the sides where you took the screws out of and pull forward and this will remove the front panel,take out the 2 top 5/16 screws one on each side that go through the metal holders,they are the screws closest top the top lid,remember how the holders hook into the top cover and the catch is in the middle of each piece,now lift the top and spin the drum so the baffle(paddle) is on the top and you can get at the screws to tighten them,the top doesn't lift to far up so you might have to lay down and tighten them from the floor,this is how i've done it ,hope this helps
Pop the top ... remove the front ... carefully remove the belt ... take the drumout - you are correct, the paddles are held onwith screws - tighten them.
Bad breaker in the panel box.Loose wires at the breaker. Loose connection in the wall outlet. Loose connection at the dryer cord terminal. Bad cord. One or more of the above.
Hi, UNPLUG the dryer. You should find two screws in the front lower part of the panel where it angels in. Remove those screws and pull the bottom toward you. The front panel should then release. Now you will need to locate the screws in each of the upper corners that hold the top to the cabinet. They will probably be 3/8" screws. The top should lift up. You can put the parts on this way. THe old screws are probably laying in the bottom of the dryer. You might need to add metal washers if the holes have longated. If I can assist you fyrther, please let me know.
You might have to remove the back, then the top, but it looks like the paddles are either held on buy a screw from the outside of the drum or they just have clips that lock them to the drum. Once the back is removed, you should be able to see how the top is held on. I think it is screwed or has clips for the back and then you slide it forward to unlock the front tabs. You can follow this if you don;t get a reply from someone who has worked on this model#. Hope you get it apart ok and fixed by yourself.
Have to take the front off and title back the top to get inside the dryer
