I have model no : LG KF600, when I insert SIM this gives me error
Hi I have model no : LG KF600 , when I insert SIM this gives me error with 'Insert right Sim card', but I receive phone call on the cell, can anyone gives me the solution of this, that how to un-lock this so that the error can be resolved.??
How to Unlock LG (most models):
1. Insert not-allowed SIM card
2. Power on the handset- phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM unlock code
5. Select "OK" - the handset is now successfully unlocked
Unlock Instruction for LG TU720 (SHINE) and VU
1. Power ON your phone with not allowed sim card (one that didn't come with the phone)
2. Type *#865625#
3. the phone will ask you to input the unlock code twice, just input the unlock code
4. Device is now unlocked
How to Unlock LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Unlock LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
4. Enter the SIM Unlock code
How to Enter Unlock Codes on LG F2250:
1. With allowed sim card in the start menu type: 2945#*3311#.
2. Handset shows saved, then return to startup screen
3. Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4. Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1.
Switch ON your phone with a not allowed SIM card.
2.
Compose: 277634#*#.
3.
Go to menu "SIM Lock".
4.
How to Enter Unlock Codes on LG U8110:
1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2. Select 'Sim Unlock' menu #
3. Enter NCK code then validate
4. Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1. With a not allowed sim card enter Pin code then validate, type: 277634#*#
2. Shows test menu
3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4. Handset shows 'Enter NCK'
5. Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2. Enter the code
In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1.
Insert non-Cingular SIM card.
2.
Power on the handset. Phone will display "Invalid SmartChip"
3.
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4.
In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5.
Enter the 8 digit SIM unlock code
6.
Select "OK". The handset is now successfully unlocked.
Unlock Instructions for LG KU990 (Viewty):
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF600:
2. Enter 2945#*71001#
3. A menu will pop up to enter the sim unlock code
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF750 aka LG SECRET:
1. Insert original sim card and turn phone on.
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
Unlock Instructions for LG CU915:
1. Power ON your phone with an accepted SIM card.
2. Type *#865625#CODE
3. Press OK
How to Enter Unlock Codes on LG Incite CT810:
1.
Dial this into the LG Incite's phone menu
2.
2945#*810#
3. Press CALL.
4. It should you ask you for the code.
How to Enter Unlock Codes on LG Invision CB630:
1.
Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2.
3.
*#865625#
4. Press CALL.
5. It should you ask you for the code.
How to Enter Unlock Codes on all other LG cell phones:
1.
Switch ON your phone with an allowed SIM card
2.
Then compose:
3.
2945#*5101# - (if you have a LG 510w)
4.
1945#*5101# - (if you have a LG 1200 & B1200)
5.
2945#*5221# - (if you have a LG 5200 & 52200)
6.
2945#*5301# - (if you have a LG 5300)
7.
2945#*5401# - (if you have a LG 5400)
8.
2945#*70001# - (if you have a LG 7020)
9.
2945#*7101# - (if you have a LG 7100)
10.
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
11.
2945#*70001# - (if you have a LG7250T)
12.
2945#*2201# - (if you have a LG C2200)
13.
2945#*5301# - (if you have a LG T5100)
14.
2945#*3311# - (if you have a LG C3310)
15.
Go to "Menu" and then to "Settings"
16.
Then select "Security"
17.
To finish select "Network Provider" and select "Deactivate"
18.
19. If your cell phone is not listed, please follow instructions for LG C2000 above
How to Enter Unlock Codes on LG KE970 Shine:
1.
2.
Then compose: 2945#*9701#
3. Press CALL.
How to Enter Unlock Codes on CU575 / Trax and CU515
1. Put a non cingular sim in the phone ,phone says invalid smart chip
2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
? 5:04
https://www.youtube.com/watch?v=90Rm8X8BlXM
Jun 22, 2014 - Uploaded by Michael Thomsen
In this video I show you how to insert a Micro SIM Card & MicroSD Card in to the LG G3. You can read more about the device here: http://www.lg.com/global/g3... ... The interactive transcript could not be loaded. Loading... Loading... Rating is ...Smartphone Battle: Apple iPhone 6 Plus vs LG G3! - Duration: ...
? 2:30
https://www.youtube.com/watch?v=FUMQuQ0j1Cg
Nov 23, 2013 - Uploaded by Mobile How To
How To Insert & Remove Micro SIM Card - LG G2 ... Mobile How To will not be held responsible for any errors/issues or faults that occur as a ... My would go far into the phone without anything ejecting, I tried a bit closer to the ...
As far as I know.there are two possibilities to get this error..
1)Sim card not inserted properly:
Try to insert the sim properly..insert it at the desired position
2)Phone may be locked with a particular network:
If the phone is locked with a particular network then you need to unlock
it.You can get the unlock service for your Blackberry 9360 Curve from either your network provider or
third party unlocking service provider like, unBBlock.com and
remove the network lock. Once unlocked it will
work with other networks.
3)Sim Problem:
Mostly this won't be in your case because the sim had been working fine
with your previous Nokia mobile and also the phone gives the same error
message when you insert other sim cards.
4)Hardware Problem:
There might be some loose connection give it to a hardware service shop and check.
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted. 2. Turn off mobile phone 3. Remove battery 4. Remove memory card 5. Remove sim card 6. Check the copper pins of the sim if there are dirts stucked on it 7. Ure clean cloth to wipe sim gently 8. Wait for at least two minutes 9. Gently and properly insert the memory and sim card 10. Insert the battery 11. Turn on mobile phone 13. Check if you will still recieve insert sim error 14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Are you sure you did correct instruction how to insert LG Quantum unlock code in your phone? As my knowledge when we do unlocking phone we insert the original sim card not the unaccepted sim card. Try doing that procedure again but this time use orignal sim card when you insert lg unlock code in your phone. Good luck!
Only trust best unlocking specialist for unlocking your mobile , it will be the best & safest way for unlocking . In order to unlock your Lg KS360 MOBILE make use of this site wickedunlock ,select the network you need , then get the unlock code here , using unlock code specified in it proceed unlocking your mobile & gain solution .
once you have the unlocking code this is the procedure..
3. Sim unlock mode pop up .
5. The phone will then reboot and the unlock process is complete.
i have a lg kp100, I already bought a code to unlock it, but i don't know how to insert it. the phone is locked to movistar(spain) and probably the sim has not a network anymore. I am in greece now so I tried with greek sim cards but still nothing.
when I put the spanish sim it shows me "error de tarjeta sim" wich means error with the sim card, but there is nowhere option to access to security mode to insert the unlock code.
if there is anyone who can help me please contact with me [email protected]
hi,
I have successfully install some applications on LG KF600.
0. Install application - LG Mobile Sync (to verify the driver in Control panel- system- Hardwave Device- Modem- LGXXX). If it did not show up, well it is normal. You may need to restart PC after installaion.
1. Select the USB conection (for LG KF600) from the connectivity option
2. Connect USB cable (connect to PC first) from PC to USB port of LG KF600.
NOte : your will see "portable disk" on your phone.
If you did not see it. Please stop.
3.Check My computer (from PC). Is there any NEW Removeable device appear ? Unplug and plug again from the phone and you will see it.
4. In your Removealbe device (phone), you will see 5 folder (actualy from Phone -My Stuff )
5.Copy files from PC to desired folder (phone).
Does anyone know where to get the english dictionary for LG KF600 ?
Sincerely.
So what is the solution for this and how to re-progrma this??
My LG can't read my sim card! It said "start up phone without simcard" but there is a simcard insite!!!
lg gx200 reliance sim is insert and error of invalid sim
