Reset Windows password decidedly.
Have you created a windows password reset disk before?If so, do as the below steps:
Step1: Start your locked computer and when you see Windows Welcome screen / Login screen, click "Reset password", and then insert your password reset disk.
Step2: Follow the steps in the Password Reset Wizard to create a new password.
Step3: Log on with the new password. If you forget your password again, you can use the same password reset disk. You don't need to make a new one.
Note: If you do not have a reset disk, Windows Password Reset also the great choice.
You can download a piece of software called ophcrack and burn it to a cd, then put the cd in when the computer turns on and it should be able to crack the password for you.
SOURCE: Don't remember the admin password & has several things pw protected as well..
I forgot windows 7 laptop password, i just reset windows 7 password by the following steps,
Step1: Download Smartkey Windows Password Recovery Professional from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD/USB to burn Windows 7 password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD/USB.
Step5: Start to remove Windows 7 password with the burned disk.
Step6: Reboot computer and login to the locked PC without password.
Hope it can help you well.
