Yes RUN THE software calibration inmediately for easy diagnose, troubleshooting, and fix it
God bless you
HOLD AND PRESS THE INCLINE+SPEED BUTTON BY 5 SECONDS THE CONSOLE WILL BE BEEP AND DISPLAY THE SOFTWARE ENGINEERING USING
Press START , and the machine run to o.5mph, if this not speed you can adjust the speed sensor, and proceed with the indications. God bless you
you can downloa the instr.manual from www.fitness.manualsonline.com or www.iconservice.com .
SOURCE: treadmill powers up begins to turn belt then shuts down
Have you tried to calibrate the speed. If not you might want to try it and see if it will help you with your issue.
SOURCE: Proform 765 EKG
If I understand correct, the treadmill will not run correct unless you have the safety key in. Well yes this is correct because once the safety key is removed the treadmill will stop. If your treadmill is running extremely fast just by turning it on, you may need a new speed sensor. www.AtlantaFitnessRepair.com
SOURCE: My sportcraft tx 2.5 treadmill does not have the safety key
any round magnet that will fit in the hole will work.
Testimonial: "Thanks a lot..This really helped"
SOURCE: i have a pro form performance j4 treadmill. i
It is just plastic. You can wedge a piece into the slot
SOURCE: Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Sorry Ernesto could you explain what you mean by " RUN THE software calibration" what is that and where do i find it...i got this treadmill from a family member who could not find the operating manual...
