I watched the Tv the previous Night, turn it off and went to Bed. The following day, when I turned the tv on all I get are bunch of flickering vertical lines in all kinds of color you can imagine. Even when I tried to get into the menu, I still get vertical lines just in diffrent colors. In summary, the tv is just showing vertical lines in diffrent colors (the colors are constantly changing I guess depending on what is supposed to be showing on the Tv at that particular time.) Pls help!!!!!!!!!!!!!!!!!
Soory man there is no deflection yoke or vertical output IC in a plasma TV set.LOL This person has a problem with whats called the substain power supply or bad caoacitors in the main supply. there is also a possibility that the set has a bad tuner. Only performing test on the set will determine the problem.
Take your set to a qualified tech you have a bad vertical ic or some cap around the vertical section is not filtering the voltage properly and your deflection yoke could also be bad.good luck.
Tv has. Olord vertical lines in it and the picture only stays on for about thirty seconds or less
Flickering and lines going through tv
when television is turned on sound comes on but picture only shows vertical colored lines. As the unit plays longer the lines become a neon green color. Sometimes the picture comes in but then it fades to a total black screen.
