The box say 2g and i have a 4g sd card in it and everytime you download an app it say low on space
SOURCE: pandigital novel 7" WHITE ereader wont turn on.
You
can try pressing the reset button with a straightened paperclip of pin.
If that doesn't do anything removing the back and unplug the battery.
Leave it unplugged for a minute or two and reconnect it. Be careful
unplugging it as you don't want to put to much force on the wires. You
can use a small screw driver or tweezers to pry on the plug. The white
plug here
is what you're locking for. See if it powers on and hopefully it does.
If not you may have to contact Pandigital.
Hope this helps
Ray
SOURCE: i just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
SOURCE: My pandigital novel ereader froze how do I reset it
Unplug for about ten seconds and plug back on!!!generally electronics will reset themselves....good luck!!
