They run from top to bottom and i only could see from right side of screen. can someone please tell me whats wrong
SOURCE: Coloration - poor picture
TRY UNPLUGGING SET FOR A FEW MINUTES...PLUG IN LINE CORD WHILE HOLDING PRESSING POWER BUTTON..IF THIS DOES NOT WORK..CPU BOARD IS FAILING...P/N 667-L32K5N-56I...TRY CALLING MCM FOR PARTS AVAIL/PRICE...JOE ACE
SOURCE: 1/2 of laptop screen works.......
Unfortunately, you need a new display. This is a failure of the electronics built into the display panel itself. You could hook up an external monitor if you're using the computer at a desk, but for portable operation you'll have to replace the display. Replacements are available online from different sources. Check eBay and do a Google search for your specific model and "replacement lcd". Just be sure that any replacement matches the part number of your original.
To skotkolr: Why not just answer the question? Does it really matter to you that the question was under the wrong heading?
SOURCE: there are horizontal color bands (red, yellow and purple)
You having problems with the video circuits in the television. The color bands are some type of noise from faulty components in the circuits distorting the video information for the screen.The scrolling actually is the scanning circuits. You should go to the Insignia website and check the frequently asked questions and Troubleshooting sections to see if someone else has had this problem and had the answer posted. The website is www.insignia-products.com. The telephone number for technical service is 1-877-467-4289. Hope this helps you with your problem.
SOURCE: A thin vertical green line appears half way up the
T-Con / LVDS panel defect or LCD panel defect,not repairable,only changeable.
SOURCE: When I turn on tv,
You probably have some bad electrolytic capacitors on the power supply module. The caps will be bulged or mushroomed at the top rather than flat if they need to be replaced. Parts are very inexpensive. I've fixed many of these sets by replacing bulged caps on the power supply for having same symptom of yours. That would be the first place I would start. A repair shop would probably get between $100-$150 to replace these parts if you wanted go that route.
