Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
Posted on Jun 19, 2017
BRAVIA KDL-V32A12U PICTURE LOSS
TV comes on for 45 minutes to an hour and then looses picture and sound. The red power/standby light flashes 3 times at 2 second intervals. After switching off and on again it comes on for a few minutes and repeats the symptoms. After several hours of being switched off the above can be repeated.
Same problem, only mine flashes 5 times. Seems to be in the wire between the board on the back of the tv an the power plug. Can that wire be replaced?
5 Related Answers
Anonymous
  • 22 Answers
  • Posted on Jan 16, 2008
SOURCE: TV turn on and off
Your TV has a power problem, it maybe high or low supply voltage that causes the TV to turn it self off because of an error. A technician from the manufacturer knows what error it has just by looking at the flashing standby light. Best is to take it to an authorize service center for repair... ^_^
Anonymous
  • 320 Answers
  • Posted on Nov 10, 2008
SOURCE: Flashing Standby Light (6 times every 2 second interval)
A 6 flash error indicates a problem with the backlight. Your set is less than a year old and still in warranty, so you should contact Sony and arrange for a service call to get it repaired.
Anonymous
  • 67 Answers
  • Posted on Jan 05, 2009
SOURCE: tv bravia kdl 40v3000 problem turning on
Unfortunately, this is a failure of the balancer board for the backlight. The unfortunate part is that the balancer is not available by itself anymore, and the whole panel must be replaced, as Sony only has the balancers attached to new panels. You can contact Sony directly to ask for assistance, and it usually helps.
Hope this helps you...
Anonymous
  • 67 Answers
SOURCE: Have a new Sony Bravia
There is some confusion on the model (KDL-40W500 vs. KDL-40V2500), so I will direct this toward the 40V2500.
On the KDL-40V2500, an 8X blink means the scan processer has gone bad, and the BU board needs to be replaced. If the problem is intermittent, the the AU board might be the problem, but if it all the time, bank on the BU.
A competent repair shop should be able to help you, or you can try calling Sony directly for assitance.
Anonymous
  • 10594 Answers
  • Posted on Mar 14, 2009
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
2answers
Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
try some of the solutions on this link hope one will work for you. http://www.docs.sony.com/release/KDL32S20L1.pdf look under troubleshooting for no picture good luck
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Standby button (red) flashing on tv. tv turns on briefly(no picture) and then turns off with flashing red light re-appearing.
Try tv unplug,replug about an hour later.The tv now,resetting to factory setting.The tv now,should work.Not than,the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
2answers
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
1helpful
Sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
8helpful
3answers
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
3helpful
4answers
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
2answers
Sony Bravia has sound but no picture
hi have you check the sleep timer on the tv cause it might be on and you need to turn it off
Picture Disappeariing
How many flashes are happening? If its 4 then maybe a bad panel.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
