All my music is store on Windows Media Player on my PC. I cannot transfer anything to my newly purchased MIX
SOURCE: Transferring music to Insignia MP3 player
When using your media player... you need to first figure out if you are using windows media player 9 or windows media player 10. Also what windows are you using on your computer, that makes a difference as well... Make sure you have the mp3 player plugged in properly and then...Once you are in your windows media player go to your lib tab... soon as you are in there then on the right side there should be section on where you could build a lib list. Meaning you should be able to pick the songs in your lib and just drag them over. On the bottom you should see something that says sync... Once you've choose your songs and dragged them over... all you should have to do is press the sync button and it will do all the work for you from there. And it should let you know when its complete...mine does. Hope I could help you.
SOURCE: transfering music using windows 2000
I just bought this unit on boxing day. I'm able to use it on Windows 2000 now.
The root cause is the YP-U3 you have uses MTP (media transfer protocol) instead of UMS (USB mass storage). MTP is supported under Windows XP with media player 10. But WMP10 doesn't install on Windows 2000.
If you still want to use Windows 2000, read this article
http://ask.americas.creative.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=ww_english_add,U={B8F60310-DA4F-11D3-94F4-00500463020E},Company={CEAE216D-8719-4C00-AC9F-03BC258F7B70},d=1130251443648,VARSET=ws:http://us.creative.com,case=8113
Download the exe file at the end of this article. During installation, copy the extracted file under your temp directory (c:\Documents and Settings\<username>\Local Settings\Temp by default) somewhere else. Then cancel the installation.
Now when you plug in the YP-U3, manully locate the inf file in the directory you copied. Ignore the warnings. After you install the mtp driver, you should be able to use it with SMS (Samsung Media Studio).
SOURCE: how do you put music on a Disney Mix Max (512 MB) Digital Media Player
I have Windows Vista and the first time I plugged in the Mix Max it immediately downloaded the device drivers. I opened my Windows Media Player and it already recognized the player. I just transferred songs over walla they are on the player. Hope that helps.
SOURCE: problem playing music files with new Goodmans mp3 player (GMP34G5)
i got mine about an hour ago and it works fine. don't drag and drop music files, sync them to the mp3 player using windows media player.
SOURCE: Cant transfer music from samsung back to Windows Media player
i doont no how to tranfer music to my samsung yp-k3
