Modem is a Motorola 3360
SOURCE: Need to hook up Belkin G wireless router to Motorola SB5120
I have a Motorola SB5100 Cable modem and i have a belkin N wireless ROuter..i have conncted the wire from modem to router and computer to router and it doesnt work??what do i have to do??
SOURCE: PC/Activity light
Make sure the Ethernet cable going from the modem to the computer is secure. Then go to your computers control panel and clock network connections. Look in LAN, any try to find your connection. If it isnt there , than you will need to call your ISP, and they will install it all correctly for you at no charge.
SOURCE: Modem connects to internet but I have no dial tone to make calls
I have personally seen this issue before and with an Arris cable modem the issue you are having means that there is a over current issue with your phone line. What this means is that your phones are either getting to much or to little voltage. Usually this is caused by a crossed phone wire/staple through a phone line or possibly corrosion on your line. The first step into troubleshooting this would be to check where your phone lines tie together at and make sure nothing has come loose or broken. Also if you any of your lines run outside to a phone box go in the customer side of that and check to make sure there is no corrosion. This can also be caused by a phone going bad. Go around and unplug your phone lines 1 at a time from the phone line and see if it starts responding correctly. You made need to power cycle/reset your modem when you do this to clear the error. The final way that you can tell if it is in your phone line or not is to unplug the modem from your house line and plug a phone straight into the modem. This should make at least that one phone start working correctly.
the most easy way to connect to the internet is get a bluetooth connetion (zippys) press the tools find device on the bluetooth on ur phone press pair device and press dial up inthe username put ur mobile number and password mobile number dial up number *99# dial
SOURCE: Arris cable modem
if the power light is flashing then the modem is on battery backup and internet is disabled. plug the power cord into the modem or find a working power outlet, you should be set after that.
Power light flashing=bad
