I have a JVC flat panel television, model LT-26X575 ... about a month ago the remote stopped working for turning on the TV but I could use all the other functions. Now, it has stopped working altogether. Thinking I had a bad remote, I ordered a new one. It arrived today and I still have the same problem.
Any ideas of how to fix the problem? Thanks!
1 if this new ordere it is exacly the same that should work when i say exacly that must have only the same button on it
2 you should try to take off the cover to that old remonte and try to clean the taste and then the change battery clean suport to battery wash your rubber taste and put all togheder and should work if that not hapened the problem it is from inside tv
and to that new one see if you have a shift buttun on it and push that or push tv button and try again should work
JVC LT-26X575 has a yellow "04" permanently displaying in upper right part of screen. How can I delete it.
JVC LT-26X575 has a yellow "04" displaying in upper right part of screen. How can I delete it?
