One video that might help, but this is a $500 camera, so take it in for service. It needs to be serviced in a clean dust free lab by men in white coats and cotton gloves.
I have had the same problem. I removed the heater element and checked the resistance with my multimeter and got the reading of 26.4Ohms which sees ok. I then removed the printed circuit board and found that a joint on the back had burnt out. I have resoldered this joitn and all seems fine now.
F08 fault means your heater relay is stuck.Remove plug and wait 5 mins {MACHINE MAY NEED TO DISCHARGE POWER BOARD} THEN CHECK heater connections and main powerboard connections. heater is located at back of machine and powerboard at back lhs
Sometimes, the manufacturer doesn't put the part number on the boards. You need a schematic to get the actual part number they use. You can try to call the manufacturer and ask them for the proper part number or try the website below. They have free tech support and might even have the board you need:
https://www.discount-merchant.com/
finally got some help from customer service ----
the code flashing one then two red lights is for an upgrade of the software ---- you can go to their website and download a current fix to that problem onto a thumb drive----
\the power problem is caused by a bad power board--- you can replace them for any where from 130-330.00
dont need a service tech - take off cover and easy to replace---can find part on parts store.com for philips televisions --- used is about 130 and new about 330 -- used is a refurbished unit and works just as good as the new one
