Amana 25" Cu Ft French Doors Bottom Freezer Refrigerator, AFD2535DE Logo
Posted on Dec 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brand new Amana French Doors Refrigerator is too cold.
Brand new Amana French doors bottom freezer. Freezer temperature is ok. Refrigerator temperature remains below freezing at all areas on shelves and Chef's pantry and crisper. I've set the refrigerator temperature all the way up to 45 degrees and it still freezes (i've checked the temperature on 2 different refrigerator thermometers that I have, refrigerator temperature shows at or below 30)
Anonymous
Level 3:
  • Amana Master 43,501 Answers
  • Posted on May 24, 2010
Anonymous
Amana Master
Level 3:
Answers
43501
Questions
0
Helped
10843463
Points
101584
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorBrand new Amana French Doors Refrigerator is too c - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Amana fridge stopped working for 2 days
Do you see any ice buildup on the back wall of the freezer or behind it?
My amana 25 ft bottom freezer stopped cooling
what you might need is a new Compressor part number W10566381
the pic below is the Compressor that you might need
2answers
Condensation on the strip between the 2 french doors
these fridge have a heater in that black flaper to prevent condensation. It is probably not working or not even plugged...do they removed the doors when they delivered your fridge??? remove the uper left cap of the hinge, the connection is there...... the tech must check that piece if it is well plugged..
Amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
3helpful
Anama bottom freezer
Chances are if they are getting cool -
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator/freezer.
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
