Question about Sharp AR-5316 Advanced Digital Imager Copier
SHARP AR 5625 CODE ERROR U2-40 - Sharp AR-5316 Advanced Digital Imager Copier
    New Friend:
Sharp AR 5625 Erreur H3 - 11 ?????
Posted on Jan 08, 2014
5 Suggested Answers
6ya staff
SOURCE:
Chuck Clark
  • 33 Answers
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Posted on Jan 02, 2008
Anonymous
  • 682 Answers
SOURCE: request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Posted on Apr 19, 2008
Anonymous
  • 95 Answers
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Posted on Apr 12, 2009
Anonymous
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
Sharp ar 5625 error f2-02 ?
Dear
The failure of toner supply may cause this code. this may be due to the exhaust of toner or CRUM life end. From hardware point of view the hopper (toner feeding ) assembly and its sensor to be checked.
Thanks.
Feb 03, 2015 | Sharp Office Equipment & Supplies
I have a sharp AR 5625 photocopy machine that brings a message 'maintenance is required ' how do i solve it?
Are You the Administrator for the System?then go to the folder On the computer it's connected to and run Diagnostics from there, And Or from the control Panel/ Devices/Hardware,Also Right click Computer go to Properties device manager click on Printers if you have a yellow Icon on anypart of that list then y have a software Problem, go to MANUFACTURE Web site and Download the latest sofware for you're machine restart after install and you should Be fine , ALSO DON'T forget to run you're computer tools Like disk clean up and disk defragmenter, to keep you're System in top working order
May 24, 2012 | Alienware PC Systems ALIENWARE 5620D...
I have a sharp ar 5625 photopy machine that brings a message 'maintenance is required' when i power it on,how do iclear it?
You don't !!!! Follow the Procedure to perform the Maintenance and It will go away on it's own.Also You might want to Check to see if you have the Latest Drivers for you're System to keep it running Smooth and secure
Error for sharp ar 5625 h4
saharp ar5625 u240 erorr code
May 15, 2011 | Computers & Internet
Sharpe ar-163 with error code u-240
Hello sir; The error code you display is CRUM communication error.
Feb 05, 2010 | Sharp AR 163 Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Request service manual for sharp AR-5316
Apr 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
788 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
