Question about Danco Flat Washer 2-1/4"X3/4"X1/8"
What are the different types of flat washers?
    New Friend:
    Problem Solver:
  • 15 Answers
The different types of flat washers include: Fender washers Type A washers Type B washers Nylon washers
You can find more information on these types of flatwashers on this link: http://www.ehow.com/list_6516551_types-flat-washers.html
Posted on Jul 15, 2012
6ya staff
SOURCE:
What is the price for drain pump washer for a danby washer
It all depends on if your talking about danby's dishwasher or a washing machine by Danby.
there are also two different types of washers metal and rubber. these are different from gaskets which go between two parts.
As for the rubber washer danby has a list of authorized retailers and service depots that sell their products. These retailers will list replacement parts specific to your type of washer rubber gaskets are typically 50 cents up to fifteen dollars but the rubber washers i found on www.apwagner.com was around 2.50 cents depending on the model.
Also if your looking for gaskets the same list applies to replacement parts but they are more specific and are pricer costing upwards of 10 to fifteen dollars or more.
Nov 25, 2012 | Washing Machines
What sizes do flat washers come in?
Flat washers come in many different s and are dividedinto three series: Narrow, Regular, and Wide. For a complete list of s,check out this website: http://www.engineersedge.com/plain_washers.htm
Jul 15, 2012 | Danco Flat Washer 2-1/4"X3/4"X1/8"
What materials are the different flat washers made of?
Different flat washers are made from different materials.Those materials include zinc, stainless steel, carbon steel, different types ofrubbers, and plastic.
Kenmore series 80 washer does agitate properly. The bottom vanes move but the top part does not.
Hello, welcome to FixYa.
Based on your description, the problem is likely worn agitator dogs/gears. The new dogs alone part # 3109 or what I'd recommend, part #8537434 as a kit with new hub too. An example is shown here...(double check with your complete model number to be certain)
These are very common and available at most brick & mortar parts depot's as well as on-line vendor's such as "repairclinic.com" or "searspartsdirect.com" to name a couple.
You`ll need to remove the top of the agitator to replace them.
To remove the top cover of the agitator, it should lift off by prying up gently with a flat screwdriver or puddy knife.
Under this cap there actually is a screw/fastener,( bolt ) it just may or may not look anything like a typical screw.
It could be a plastic piece with a square center and with the aid of a large flat screwdriver inserted in this location pressed into one of the corner`s in the square center (as to hold it still or turn it,I usually hold it still while turning the agitator) at the same time as holding the bottom of the agitator, turn it counter-clockwise and it will come loose. It may be the bolt style and in that case just remove the bolt and lift it out.
On Whirlpool washer (this is who built your Kenmore) throughout the years there are several types, ones with a 7/16", 1/2" or 9/16" bolt holding it in place, and the type I described. Based on the model number (11024966300) you provided yours will be the 7/16" bolt.
This is a link to a helpful "how to" video...it may have slight differences to your washer, and may refer to a different part number but essentially the same...it is still Whirlpool/Kenmore.
http://www.youtube.com/watch?v=0GQh8JLqVv8&feature=related
Thank`s for visiting FixYa. Good luck and let me know if I can assist you further.
Regards,
Macmarkus :)
Oct 31, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Whirpool Ultimate Care II washer. It agitates, but not very well. If I push down on the agitator it agitates better. Any suggestions?
Welcome to FixYa.
Based on your description, the problem is likely worn agitator dogs/gears. The new dogs alone part # 3109 or what I'd recommend, part # 285809 for your specific model as a kit with new hub too.
i.e.
These are common and available at most brick & mortar parts depot's as well as on-line vendor's such as "repairclinic.com" or "searspartsdirect.com" to name a couple.
(as to hold it still or turn it, I usually hold it still while turning the agitator)
On Whirlpool washer throughout the years there are several types, ones with a 7/16", 1/2" or 9/16" bolt holding it in place, and the type I described. Based onthe model number you provided yours will be the 7/16" bolt.
This is a link to a helpful "how to" video...it may have slight differences to your washer, and may refer to a different part number but essentially the same...it is still Whirlpool.
Regards,
Macmarkus :)
Jan 15, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
What type of oil do I use for the 2550PSI pressure washer engine and how do I change the oil completely?
To empty the oil you tip it over on it's side. The type of oil to use is car oil and depends on the temperature where you live. The manual is available at http://staging.us.kohler.spectracom.com/pdf/owners_manual/101%5C020273_0_om-Domestic.pdf and on page 18 it tells you the type of oil for different temperatures.
Jan 09, 2011 | Briggs Stratton 020273 Elite Series...
I need a hose for my washer and need to know the part number in orser to order a new one.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Nov 04, 2010 | Kenmore HE2 Plus Front Load Washer
Taking the washer apart for repair. I have a different type of control panel than is described in the help videos
There are a couple of different types of control panel mounting methods.
1: there are two phillips heads screws at the bottom of the control panel (just above where it mates to the top of the washer) on the left and right sides that go through the end-caps. The screws are either in the front side of the end-caps or in the back side. They need to be removed to allow the panel to be slid forward slightly and then lifted to be tilted back.
2: The newer style machines are now using spring clips that will need to be depressed with a thin bladed putty knife. You will have to slide the putty knife straight in under the front of the plastic end-caps to release these clips. Pressing them too hard may cause them to pop out of the end-caps , but you can easily re-install them if that happens.
After you get the console loose, you can disconnect the wire jack that goes to the lid switch assembly and then use a flat blade screwdriver to release the cabinet mounting clips.
With the cabinet clips removed you can open the lid and grasp the top of the washer and pull it forward to remove it from the base of the washer.
Good luck, and let me know if you have any other questions!
Jun 27, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Lid not turning washer on
Sounds like a lid switch problem most likely. When closing the lid, slowly lower it and listen/feel for a "click" when the lid is about 3 inches from being completely closed. If you don't, then you have a broken lid switch.
The model of washer you listed, TAWS800JQ, has two different possible lid switches and you get to them differently.
To get to the lid switch, you need to remove 2 screws that hold the control console in place. There is 1 on the left and 1 on the right of the console. They can either be on the front side and easy to see, or on the back side. Loosen those screws so that the console is free and you can flip it up and backwards out of your way.
One type of lid switch can be seen on the left side after you flip the control console up and back out of your way. There is just a little clip that holds it in place. The lid needs to be raised in order to remove the lid switch. Unplug the wiring harness and replace.
The other type, do this:
Then use a flat blade screwdriver to remove the brass spring clips on the left and right side of the washer that hold the front/sides/top on. Unplug the lid switch in the middle of the washer top and then you can remove the wrap-around cabinet. The lid switch is under the top and is held in place by clips and 2 screws.
May 29, 2010 | Estate TAWS800JQ Top Load Washer
I have a commercial T & S Brass Faucet that leaks. I have replaced the washers with different sizes ( 0, 00, etc) and still drips. I think I'll try the Beveled type, but would love for someone to tell me...
The seat probably need either ground flat or replaced. Pull the stem and inspect where the washer seats for grooves or an uneven surface.
They make a seat tool specifically for seat removal but a fairly large allen wrench usually will work if you don't have access to one. If it's not too deep of a groove you can rub it on a piece of fine grit sand paper but make sure it's flat on the surface and not slanted. If it's very deep at all, you will be better off to take it to the local plumbing supply to match it for replacement.
As far as the washer, T&S used slightly different sizes of washers depending on the model but just use the largest one that will fit inside the lip and flush with the bottom of the stem and it will seat well. I generally have better luck with the beveled.
Dec 18, 2008 | T & S Brass T&S Brass B-0228 Deck Mixing...
Danco Flat Washer 2-1/4"X3/4"X1/8" Logo
304 people viewed this question
Top Danco Home Experts
mehan
Level 1 Expert
chedester
Level 1 Expert
Tom Chichester
Are you a Danco Home Expert? Answer questions, earn points and help others
