I have purchased a one 4 all remote but it hasn't got a retune function
SOURCE: problems turning up my sky remote on a technika tv
It depends which model of Technika TV you have. Visit here....
http://www.skymediauk.co.uk/oneforall.php
for some of them.
SOURCE: Technika tv code for a universal remote?
Hello
Three digit universal remote codes for Technica TV are:
000/ 001/ 004/ 005/ 008/ 009/ 013/ 042/ 046/ 053/ 058/ 076/ 105/ 109/ 170/ 174
Four digit codes are:
0031 0004 0005 0009 0051 0053 0105 0109 0170 0000 0174 0001 0008 0012 0042 0058
OK.
SOURCE: technika tt-16 universal remote control codes for a beko tv
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
SOURCE: no tv codes for my jumbo universal remote control
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
