Need code for: Delco electronic CDR 500 Serial Nr. GM1500Y9528808, No. 09136107. Please help
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your vehicle manufacturer's servicecentre and get them to enter this code for you.
SOURCE: I would like the radio code for a Vauxhall's delco
Unfortunately DELCO codes (including yours) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
Testimonial: "Yes, you seem to obe right, thanks."
SOURCE: delco electronics cdr 500 no.09136107 type :
no.09136107
type : CDR500 ( E )
2F4
MADE IN HUNGARY
BROADCAST CODE : CMAD CA 135124, 14
SUPPLIER : 4660103 MH
e1 21554
SOURCE: I need a safe code for my Opel Vectra CDR 500
code can only be found on car pass , if lost replacement availabe from dealer just take logbook with you plus fee £25. Otherwise take to local car audio shop for decoding.
SOURCE: i have disconnected my cdr 500 delco electronics
Unfortunately DELCO codes will not be available for free (using the serial number ) from anywhere on the Internet as access is required to the original manufacturer`s database...and this is only available (using the Serial Number ) at the Main Dealer or one of the larger Professional Decoding Services.
The better option is a Decoding Service or your local Car Radio / Audio shop only who will plug in a laptop to read/recode the memoery chip (EEPROM)
SOURCE: need the code for my astra radio its a vd0 cdr 500
Unfortunately the majority of SIEMENS/VDO codes (including your CDR500 ) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
