Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Anonymous Posted on Jul 15, 2012
My washer got out of balance and it stopped. now it won't start, and start button is flashing
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Jul 15, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
Helped
4235
Points
55
U have to relevel the tub and washer
3 Related Answers
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on May 20, 2011
SOURCE: error code FL flashes and
FL error - Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
You coudl se this manual: Service_Manual_PDF
Hope this helps.
kevin_getz
Kevin Getz
  • 1032 Answers
  • Posted on May 08, 2012
SOURCE: I have a whirlpool wfs1072Aw 7.5kg washer that has stopped spinning and won't start even the wash cycle
You probably have either a bad gearcase, timer, or lid switch. Defective motor is also possible.
Anonymous
  • Posted on May 21, 2012
SOURCE: Start button blinks; won't empty; won't leave wash cycle
turn your dailer to spin cycle
1helpful
2answers
WHAT IS ERROR CODE UL
Unbalanced Load
If uL (unbalanced load) appears in display, the load is out of balance. The washer is running a load-balance correction routine. Allow the washer to continue. If the dial is flashing and the washer has stopped, redistribute the load, close the lid, and press START/PAUSE.Dec. 14, 2019
uL - Error Code - Washer - Product Help ' Whirlpool
producthelp.whirlpool.com > ... > Error Codes
White Balance pre icon won't flash
After selecting "PRE" you are releasing the WB button and then pressing and holding it?
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
2answers
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Frigidaire front load washer model LTF7000ES0 got out of balance with a heavy pillow and we had to stop it. Now it won't do anything. Everytime I start it, the door light comes on as usual, then a
Check to see if the door sags at all and doesn't line up correctly with the door latch. Then check to see if the drum wobbles when you rotate it yourself when not in use.
Speen Queen washer won't start
Count the number flash,s before a pause.
This is the error code
My washer spin and unlock button starting flashing and when I try to unlock the washer, it won't let me. I have a feeling the load was off balance. What can I do to unlock it?
Access the drain hose and get the end to ground level in a bowl. Empty any water. Clear filter and make sure drain pump is free. Door will now open
1helpful
Washer will start then stop and the no spin light comes on and wont go no further
Check the springs and dampers are all in place. The machine thinks it is out of balance and won't spin until it's rectified.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
