I have a dell 1545 dell inspiron I burned a copy of Ubuntu to a disk well now it says missing firmware I tried the update and it said there were no updates avail
Loading Missing Firmware
As described in the section called "Devices Requiring Firmware", some devices require firmware to be loaded. In most cases the device will not work at all if the firmware is not available; sometimes basic functionality is not impaired if it is missing and the firmware is only needed to enable additional features.
If a device driver requests firmware that is not available, debian-installer will display a dialog offering to load the missing firmware. If this option is selected, debian-installer will scan available devices for either loose firmware files or packages containing firmware. If found, the firmware will be copied to the correct location (/lib/firmware) and the driver module will be reloaded.
Which devices are scanned and which file systems are supported depends on the architecture, the installation method and the stage of the installation. Especially during the early stages of the installation, loading the firmware is most likely to succeed from a FAT-formatted floppy disk or USB stick.
Note that it is possible to skip loading the firmware if you know the device will also function without it, or if the device is not needed during the installation.
how do i download missing firmware for ubuntu - warning.pngc="/uploads/images/warning.png" alt="warning.png" class="h_mi" />
Support for loading firmware is still relatively basic and is likely to be improved in future releases of the installer. Currently debian-installer will for example not display any warning if you choose to load missing firmware, but the requested firmware is not found. Please report any issues you encounter by filing an installation report (see the section called "Submitting Installation Reports").
Preparing a medium
Although in some cases the firmware can also be loaded from a partition on a hard disk, the most common method to load firmware will be from some removable medium such as a floppy disk or a USB stick. The firmware files or packages must be placed in either the root directory or a directory named /firmware of the file system on the medium. The recommended file system to use is FAT as that is most certain to be supported during the early stages of the installation.
Tarballs containing current packages for the most common firmware are available from:
Just download the tarball for the correct release and unpack it to the file system on the medium.
If the firmware you need is not included in the tarball, you can also download specific firmware packages from the (non-free section of the) archive. The following overview should list most available firmware packages but is not guaranteed to be complete and may also contain non-firmware packages:
It is also possible to copy individual firmware files to the medium. Loose firmware could be obtained for example from an already installed system or from a hardware vendor.
Firmware and the Installed System
Any firmware loaded during the installation will be copied automatically to the installed system. In most cases this will ensure that the device that requires the firmware will also work correctly after the system is rebooted into the installed system. However, if the installed system runs a different kernel version from the installer there is a slight chance that the firmware cannot be loaded due to version skew.
If the firmware was loaded from a firmware package, debian-installer will also install this package for the installed system and will automatically add the non-free section of the package archive in APT's sources.list. This has the advantage that the firmware should be updated automatically if a new version becomes available.
If loading the firmware was skipped during the installation, the relevant device will probably not work with the installed system until the fhow do i download missing firmware for ubuntu - note.png(package) is installed manually.
If the firmware was loaded from loose firmware files, the firmware copied to the installed system will not be automatically updated unless the corresponding firmware package (if available) is installed after the installation is completed.
hope this helps
SOURCE: Ubuntu sound problem
Hi Josh
First of all check system setting.
It seems like your modules are not loaded, if you just installed, I recommend you to
re-install Ubuntu, if this is not the case, try to run -
sudo apt-get -f install
If everything fails, try this - sudo /etc/init.d/alsa-utils start
SOURCE: Ubuntu Video Driver repair
Go to system > Admin > Restricted Driver Manager.
Enter your Admin password.
Two things might happen now either ubuntu will download the drivers it needs or it will provide you with a list of the drivers on your computer allowing you to choose one.
Enjoy your stay in ubuntu land.
SOURCE: Download Ubuntu
Hello Eitan,
I will provide you the direct download link for Ubuntu latest version. And this the original version.
Here is the link:
http://www.ubuntu.com/getubuntu/download
You will have two options either you can download the CD version or DVD version. Also you will have the case studis, online support and the documentation for installing Ubuntu.
SOURCE: Missing floppy disk in 64bit ubuntu 8.10
I solved the problem now, so I hope it works for you. In the /etc/modules file, I added "floppy" top the list. I think the developers just removed the module loading for floppies because so few people need them now. This change should get the floppy module to load at boot. Note that you can also use the modprobe command to accomplish the same thing, but if you want it to load automatically upon booting, modify the /etc/modules file.
SOURCE: gurb hangs after installing Ubuntu on raid 0
I too upgraded from Ubuntu 9.04 to Ubuntu 9.10 using wubi, the Windows ubuntu installer. Everything was fine, and I even admired the beautiful desktop, added KDE. I was very impressed until came the time to reboot. Grub hung. I entered the console and tried to repair: To no avail.
I reinstalled Ubuntu/Gnome without installing KDE. All went fine until the time to reboot. It hung again. After several trials, I decided to go back to Ubuntu 9.04.
From what I could gather on the Internet, it has to do with the new type of file system ext4. If only I had the choice to use it or not.
Since I was using wubi and was not offered the choice to install the ext4 file system, I do not know whether that choice is offered on a full scale installation without wubi. You might try to find out if you can customize the installation process and not select the ext4 file system, if possible.
One remark concerning the amount of swap space you are setting aside. In my opinion that's too much: I have a 2GB RAM, about 300MB swap space, and each time I monitor swap usage I find it very low to nil.
Concerning Ubuntu 9.10, I will wait until the bug(?) is fixed before upgrading. Good luck to you
I hope it helps
Thank you for using FixYa.
http://www.ubuntu.com/download
Ubuntu 10.10 Latest Version
which can repair what windows has ruined and is unable to fix fix the problem
either burn it to a disk as an iso and install
you might have burn it to an iso first then boot from the cd rom to install ubuntu or you might just try to install ubuntu directly from the download if it does not install you might save it to a folder then burn it as an iso http://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
once your computer has corrected and installed ubuntu you will be able to reinstall windows
or keep ubuntu and install windows next door to it
you can have a dual boot computer with both windows and ubuntu linux you will need to partition your hard drive to do this
is a free partition program
http://download.cnet.com/minitool-partition-wizard-home/3000-2094_4-10962200.html
hope this helps
