This error means 2 alternatives : a) elevation motor NOT working + b) display not working too. However you are mention that after 3 seconds the machine goes stop.This reveal that you must to do the following: 1) LUBE the deck belt very well, lack of maintenance shut down the machine for protection. 2) LUBE the rollers bearing,too 3) test the input voltage motor, if there are the motor need repair 4) measure the output voltage board, for input voltage motor, if there are not the board is faulty. see the block diagram 1) alternative for error codeLa) elevation motor LUBE the gear and shafft and adjus the pot.,tight any wires connector and clean 2) alternative for error code 7 b) adjust the REED switch, clean and tight the wires connector very well. see the block diagram after you fix RUN the software calibration for diagnose, troubleshooting and fix it. God bless you
To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
Error Code E05 Canon MP258 may solve by the following steps. 1.Press Stop/Reset button for 5 seconds.2.After five seconds release the button.3.Now your printer will start its process and it is ready to use... thanks
3E - MOTOR RESTRICTION ERROR Hall Senior is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error is displayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
