If you are not getting any power then the first thing to check would be the 2 fuses on the power supply board. Below is a picture of the power supply board with the 2 fuse locations circled in yellow. The fuse values are printed right on the board, just use a multitester to check to see if they are blown. If the fuses are both good then the next thing would be the filter capacitors on the power supply board. The second picture below shows the capacitors to check. Look for bulging tops, they should be flat. If any show signs of bulging then they will need to be replaced too. You can get a kit of the capacitors at this link:
http://www.ccl-la.com/catalog/product_info.php?cPath=21_77&products_id=214
I hope this helps,
BuddyMc
